cancel
Showing results for
Search instead for
Did you mean:
Intel SSD 520 180GB: Huge Power-Off_Retract_Count: risky?
HKram1
New Contributor
There are quite some threads on this forum about the Power-Off_Retract_Count like /thread/55642 https://communities.intel.com/thread/55642
/thread/31232 https://communities.intel.com/thread/31232
/thread/27813 https://communities.intel.com/thread/27813
Unfortunately I don't have any warranty; every time I shut down, it counts: HP 2560p with i7 2620m, Debian stretch). I have also tested the ssd in a DVD sata caddy in the 2560p, the SSD is the only drive!
Any hints?
Even tested with a second computer (Asus dual core): exactly the same situation (Debian stretch and Lubuntu 18.04 LTS
Model Family: Intel 520 Series SSDs
Device Model: INTEL SSDSC2BW180A3
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
5 Reallocated_Sector_Ct -O--CK 100 100 000 - 0
9 Power_On_Hours_and_Msec -O--CK 094 094 000 - 5376h+51m+45.180s
12 Power_Cycle_Count -O--CK 095 095 000 - 5899
170 Available_Reservd_Space PO--CK 100 100 010 - 0
171 Program_Fail_Count -O--CK 100 100 000 - 0
172 Erase_Fail_Count -O--CK 100 100 000 - 0
174 Unexpect_Power_Loss_Ct -O--CK 100 100 000 - 1256
183 Runtime_Bad_Block -O--CK 100 100 000 - 544
184 End-to-End_Error PO--CK 100 100 097 - 0
187 Uncorrectable_Error_Cnt -O--CK 100 100 000 - 0
192 Power-Off_Retract_Count -O--CK 100 100 000 - 1256
199 UDMA_CRC_Error_Count -O--CK 100 100 000 - 0
225 Host_Writes_32MiB -O--CK 100 100 000 - 178974
226 Workld_Media_Wear_Indic -O--CK 100 100 000 - 65535
227 Workld_Host_Reads_Perc -O--CK 100 100 000 - 64
228 Workload_Minutes -O--CK 100 100 000 - 65535
232 Available_Reservd_Space PO--CK 100 100 010 - 0
233 Media_Wearout_Indicator -O--CK 100 100 000 - 0
241 Host_Writes_32MiB -O--CK 100 100 000 - 178974
242 Host_Reads_32MiB -O--CK 100 100 000 - 327492
249 NAND_Writes_1GiB PO--C- 100 100 000 - 8431
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
|||____ S speed/performance
||_____ O updated online
|______ P prefailure warning
Is it risky to use this ssd? I don't have any problems apart from these smart values...
The latest HP bios is installed and the latest 520 firmware as well. AHCI is set on bios-level. SSD is optimized in Windows 10
3 REPLIES 3
Esteemed Contributor III
Hello gipfeli,
Thanks for posting in our communities.The Power-Off Retract Count SMART attribute counts the number of unsafe or unexpected power loss. According to the https://www.intel.com/content/dam/www/public/us/en/documents/product-specifications/ssd-520-specific... Intel® SSD 520 Series Product Specification this is not a pre-fail value.However, it may lead to data corruption. For comparison, please boot into Windows 10* and provide us with the following information:- SSD SMART details from https://downloadcenter.intel.com/download/27460/Intel-Solid-State-Drive-Toolbox?v=t Intel® SSD Toolbox. Please use the export feature and save it on your system.- Please download and run the https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91... Intel® System Support Utility and select Save.Please attach both files to your next reply.Best regards,Eugenio F.
HKram1
New Contributor
Hi Eugenio
Thanks for your answer, but with linux, there is only smartctl or gsmartcontrol. However on the lenovo Forum (it's a intel 520 ssd 180GB, Lenovo oem version) I have found a firmware upgrade. https://forums.lenovo.com/t5/ThinkPad-X-Series-Laptops/x230-SATA-errors-with-180GB-Intel-520-SSD-und... M55353 https://forums.lenovo.com/t5/ThinkPad-X-Series-Laptops/x230-SATA-errors-with-180GB-Intel-520-SSD-und... M55353
The counter has stopped after the installation of Versiion LB3i. It wouldn't do any harm to mention in the Intel documentation that this firmware version fixes the power off retract count issue... Best regards H. Kramer
Hello H. Kramer,
Thanks for sharing the solution.We were not aware this is an OEM version of the SSD, these drives have different firmware versions from the retail models. However, this information could help other Lenovo* users.Best regards,Eugenio F.
