cancel
Showing results for
Search instead for
Did you mean:
Intel SSD 520 Series Disconnecting/Reconnecting, what to do?
ENeto
New Contributor II
Abount an year ago I bought an ASUS Zenbook UX32VD with an Intel SSD 520 Series 480GB.
I got rid of Windows 8 (that ended up inside Virtualbox) and installed Linux, that time was Linux Mint 14 Nadia and now I have Linux Mint 17 Qiana, since the beginning I noticed occasional crashes that the logs ended pointing out the culprid was the SSD drive.
The kernel keeps logging that several times a day:
kernel: [15833.344939] ata1: exception Emask 0x50 SAct 0x0 SErr 0x4090800 action 0xe frozen
kernel: [15833.344952] ata1: irq_stat 0x00400040, connection status changed
kernel: [15833.344971] ata1: SError: { HostInt PHYRdyChg 10B8B DevExch }
kernel: [15833.344975] ata1: hard resetting link
kernel: [15834.068392] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
kernel: [15834.079528] ata1.00: ACPI cmd f5/00:00:00:00:00:a0 (SECURITY FREEZE LOCK) filtered out
kernel: [15834.079606] ata1.00: ACPI cmd ef/10:06:00:00:00:a0 (SET FEATURES) succeeded
kernel: [15834.079615] ata1.00: ACPI cmd ef/10:03:00:00:00:a0 (SET FEATURES) filtered out
kernel: [15834.099770] ata1.00: ACPI cmd f5/00:00:00:00:00:a0 (SECURITY FREEZE LOCK) filtered out
kernel: [15834.099825] ata1.00: ACPI cmd ef/10:06:00:00:00:a0 (SET FEATURES) succeeded
kernel: [15834.099837] ata1.00: ACPI cmd ef/10:03:00:00:00:a0 (SET FEATURES) filtered out
kernel: [15834.109697] ata1.00: configured for UDMA/133
kernel: [15834.124335] ata1: EH complete
It says it needed to hard reset the sata link.
Occasionally it keeps doing that, downgrading the link speed to 3.0 Gbps then try with 1.5 Gbps, never stops and the system crashes.
I readed a ton of claims of people with the same problem principally with lenovo computers and the solution is always the same "I ended up exchanging my Intel 520 SSD for a Samsung 840 Pro" and now I don't have any problem.
I have a Samsung 840 Pro SSD with 512 GB that doesn't do that. Another interesting thing that happens with my Intel 520 and not with my Samsung 840 Pro is that if I put them in an external USB 3.0 case (I tested with a 2.0 USB case of another brand too), the Samsung works fine, but the Intel SSD keeps disconnecting and reconnecting all the time at a point to be impossible to use it, no matter what the computer/system I connect it to, Windows/Linux.
Is that normal? An Intel 520 Series 480GB SSD be unusable through USB, and only be usable because the kernel can handle its disconnections when connected through the SATA connector, and still ocassionally crashing?
I was considering buy another Samsung 840 Pro as the Intel 520 one will not serve me even as a backup drive.
15 REPLIES 15
Jose_H_Intel1
Valued Contributor II
We would like to get as much information from your system as possible in order to investigate the disconnect issue. Kindly provide the motherboard model, processor, BIOS version, memory specifications.
In regards of the "Sound Devices" thread, that was a custom firmware released to solve compatibility issues with their products.
ENeto
New Contributor II
$ sudo LANG=en lshw
zenbook-ux32vd
description: Notebook
product: UX32VD (ASUS-NotebookSKU)
vendor: ASUSTeK COMPUTER INC.
version: 1.0
serial: CAN0AS54035743B
width: 64 bits
capabilities: smbios-2.7 dmi-2.7 vsyscall32
configuration: boot=normal chassis=notebook family=UX sku=ASUS-NotebookSKU uuid=71F8E803-25EC-4AAD-A70D-50465DE1F0AB
*-core
description: Motherboard
product: UX32VD
physical id: 0
version: 1.0
serial: BSN12345678901234567
slot: MIDDLE
*-firmware
description: BIOS
vendor: American Megatrends Inc.
physical id: 0
version: UX32VD.214
date: 01/29/2013
capacity: 6080KiB
capabilities: pci upgrade shadowing cdboot bootselect socketedrom edd int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int9keyboard int14serial int17printer acpi usb smartbattery biosbootspecification uefi
*-cache:0
description: L2 cache
physical id: 8
slot: CPU Internal L2
capacity: 512KiB
capabilities: internal write-through unified
*-cache:1
description: L1 cache
physical id: 9
slot: CPU Internal L1
capacity: 128KiB
capabilities: internal write-through data
*-cache:2
description: L3 cache
physical id: a
slot: CPU Internal L3
capacity: 4MiB
capabilities: internal write-back unified
*-memory
description: System Memory
physical id: b
slot: System board or motherboard
*-bank:0
description: SODIMM DDR3 Synchronous 1600 MHz (0.6 ns)
product: 99U5428-053.A00LF
vendor: Kingston
physical id: 0
serial: 162894E5
slot: ChannelA-DIMM0
width: 64 bits
clock: 1600MHz (0.6ns)
*-bank:1
description: DIMM [empty]
product: [Empty]
vendor: [Empty]
physical id: 1
serial: [Empty]
slot: ChannelA-DIMM1
*-bank:2
product: HMT325S6CFR8C-PB
vendor: Hynix/Hyundai
physical id: 2
serial: 00000000
slot: ChannelB-DIMM0
width: 64 bits
*-bank:3
product: [Empty]
vendor: [Empty]
physical id: 3
serial: [Empty]
slot: ChannelB-DIMM1
*-cpu
description: CPU
product: Intel(R) Core(TM) i7-3517U CPU @ 1.90GHz
vendor: Intel Corp.
physical id: c
bus info: cpu@0
version: Intel(R) Core(TM) i7-3517U CPU @ 1.90GHz
slot: SOCKET 0
capacity: 3800MHz
width: 64 bits
clock: 100MHz
capabilities: x86-64 fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx rdtscp constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf eagerfpu pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm ida arat epb xsaveopt pln pts dtherm tpr_shadow vnmi flexpriority ept vpid fsgsbase smep erms cpufreq
configuration: cores=2 enabledcores=2 threads=4
*-pci
description: Host bridge
product: 3rd Gen Core processor DRAM Controller
vendor: Intel Corporation
physical id: 100
bus info: pci@0000:00:00.0
version: 09
width: 32 bits
clock: 33MHz
*-pci:0
description: PCI bridge
product: Xeon E3-1200 v2/3rd Gen Core processor PCI Express Root Port
physical id: 1
bus info: pci@0000:00:01.0
version: 09
width: 32 bits
clock: 33MHz
capabilities: pci pm msi pciexpress normal_decode bus_master cap_list
configuration: driver=pcieport
resources: irq:42 ioport:e000(size=4096) memory:f6000000-f70fffff ioport:e0000000(size=301989888)
*-display UNCLAIMED
description: 3D controller
product: GF117M [GeForce 610M/710M/820M / GT 620M/625M/630M/720M]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration: latency=0
resources: memory:f6000000-f6ffffff memory:e0000000-efffffff memory:f0000000-f1ffffff ioport:e000(size=128) memory:f7000000-f707ffff
*-display
description: VGA compatible controller
product: 3rd Gen Core processor Graphics Controller
physical id: 2
bus info: pci@0000:00:02.0
version: 09
width: 64 bits
clock: 33MHz
capabilities: msi pm vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:45 memory:f7400000-f77fffff memory:d0000000-dfffffff ioport:f000(size=64)
*-generic:0 UNCLAIMED
description: Signal processing controller
product: 3rd Gen Core Processor Thermal Subsystem
physical id: 4
bus info: pci@0000:00:04.0
version: 09
width: 64 bits
clock: 33MHz
capabilities: msi pm bus_master cap_list
resources: memory:cfe08000-cfe0ffff
*-usb:0
description: USB controller
product: 7 Series/C210 Series Chipset Family USB xHCI Host Controller
physical id: 14
Jose_H_Intel1
What is the USB case/adapter model your are using with the Intel® SSD?
Did you try a different one by any chance?
ENeto
New Contributor II
Yes, tried 3 different cases, one from IT-CEO USB 3, one from IT-CEO USB 2 and one from Western Digital USB 2.
ENeto
New Contributor II
Nothing left to do. Intel allowed to issue a RMA. Sending it today.
