cancel
Showing results for
Search instead for
Did you mean:
Intel SSD 520 Series Disconnecting/Reconnecting, what to do?
ENeto
New Contributor II
Abount an year ago I bought an ASUS Zenbook UX32VD with an Intel SSD 520 Series 480GB.
I got rid of Windows 8 (that ended up inside Virtualbox) and installed Linux, that time was Linux Mint 14 Nadia and now I have Linux Mint 17 Qiana, since the beginning I noticed occasional crashes that the logs ended pointing out the culprid was the SSD drive.
The kernel keeps logging that several times a day:
kernel: [15833.344939] ata1: exception Emask 0x50 SAct 0x0 SErr 0x4090800 action 0xe frozen
kernel: [15833.344952] ata1: irq_stat 0x00400040, connection status changed
kernel: [15833.344971] ata1: SError: { HostInt PHYRdyChg 10B8B DevExch }
kernel: [15833.344975] ata1: hard resetting link
kernel: [15834.068392] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
kernel: [15834.079528] ata1.00: ACPI cmd f5/00:00:00:00:00:a0 (SECURITY FREEZE LOCK) filtered out
kernel: [15834.079606] ata1.00: ACPI cmd ef/10:06:00:00:00:a0 (SET FEATURES) succeeded
kernel: [15834.079615] ata1.00: ACPI cmd ef/10:03:00:00:00:a0 (SET FEATURES) filtered out
kernel: [15834.099770] ata1.00: ACPI cmd f5/00:00:00:00:00:a0 (SECURITY FREEZE LOCK) filtered out
kernel: [15834.099825] ata1.00: ACPI cmd ef/10:06:00:00:00:a0 (SET FEATURES) succeeded
kernel: [15834.099837] ata1.00: ACPI cmd ef/10:03:00:00:00:a0 (SET FEATURES) filtered out
kernel: [15834.109697] ata1.00: configured for UDMA/133
kernel: [15834.124335] ata1: EH complete
It says it needed to hard reset the sata link.
Occasionally it keeps doing that, downgrading the link speed to 3.0 Gbps then try with 1.5 Gbps, never stops and the system crashes.
I readed a ton of claims of people with the same problem principally with lenovo computers and the solution is always the same "I ended up exchanging my Intel 520 SSD for a Samsung 840 Pro" and now I don't have any problem.
I have a Samsung 840 Pro SSD with 512 GB that doesn't do that. Another interesting thing that happens with my Intel 520 and not with my Samsung 840 Pro is that if I put them in an external USB 3.0 case (I tested with a 2.0 USB case of another brand too), the Samsung works fine, but the Intel SSD keeps disconnecting and reconnecting all the time at a point to be impossible to use it, no matter what the computer/system I connect it to, Windows/Linux.
Is that normal? An Intel 520 Series 480GB SSD be unusable through USB, and only be usable because the kernel can handle its disconnections when connected through the SATA connector, and still ocassionally crashing?
I was considering buy another Samsung 840 Pro as the Intel 520 one will not serve me even as a backup drive.
15 REPLIES 15
ENeto
New Contributor II
Received another drive from Intel. I did not tested performance as I would need to disassemble my ultrabook again and Im already using a Samsung drive. Tested on another older computer that only supports SATA II and inside an USB case. It doesn't disconnects anymore. Seems to be working as expected.
