Community
cancel
Showing results for
Search instead for
Did you mean:
ENeto
Intel SSD 520 Series Disconnecting/Reconnecting, what to do?
Abount an year ago I bought an ASUS Zenbook UX32VD with an Intel SSD 520 Series 480GB.
I got rid of Windows 8 (that ended up inside Virtualbox) and installed Linux, that time was Linux Mint 14 Nadia and now I have Linux Mint 17 Qiana, since the beginning I noticed occasional crashes that the logs ended pointing out the culprid was the SSD drive.
The kernel keeps logging that several times a day:
kernel: [15833.344939] ata1: exception Emask 0x50 SAct 0x0 SErr 0x4090800 action 0xe frozen
kernel: [15833.344952] ata1: irq_stat 0x00400040, connection status changed
kernel: [15833.344971] ata1: SError: { HostInt PHYRdyChg 10B8B DevExch }
kernel: [15833.344975] ata1: hard resetting link
kernel: [15834.068392] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
kernel: [15834.079528] ata1.00: ACPI cmd f5/00:00:00:00:00:a0 (SECURITY FREEZE LOCK) filtered out
kernel: [15834.079606] ata1.00: ACPI cmd ef/10:06:00:00:00:a0 (SET FEATURES) succeeded
kernel: [15834.079615] ata1.00: ACPI cmd ef/10:03:00:00:00:a0 (SET FEATURES) filtered out
kernel: [15834.099770] ata1.00: ACPI cmd f5/00:00:00:00:00:a0 (SECURITY FREEZE LOCK) filtered out
kernel: [15834.099825] ata1.00: ACPI cmd ef/10:06:00:00:00:a0 (SET FEATURES) succeeded
kernel: [15834.099837] ata1.00: ACPI cmd ef/10:03:00:00:00:a0 (SET FEATURES) filtered out
kernel: [15834.109697] ata1.00: configured for UDMA/133
kernel: [15834.124335] ata1: EH complete
It says it needed to hard reset the sata link.
Occasionally it keeps doing that, downgrading the link speed to 3.0 Gbps then try with 1.5 Gbps, never stops and the system crashes.
I readed a ton of claims of people with the same problem principally with lenovo computers and the solution is always the same "I ended up exchanging my Intel 520 SSD for a Samsung 840 Pro" and now I don't have any problem.
I have a Samsung 840 Pro SSD with 512 GB that doesn't do that. Another interesting thing that happens with my Intel 520 and not with my Samsung 840 Pro is that if I put them in an external USB 3.0 case (I tested with a 2.0 USB case of another brand too), the Samsung works fine, but the Intel SSD keeps disconnecting and reconnecting all the time at a point to be impossible to use it, no matter what the computer/system I connect it to, Windows/Linux.
Is that normal? An Intel 520 Series 480GB SSD be unusable through USB, and only be usable because the kernel can handle its disconnections when connected through the SATA connector, and still ocassionally crashing?
I was considering buy another Samsung 840 Pro as the Intel 520 one will not serve me even as a backup drive.
ENeto
SMART information:
smartctl 6.2 2013-07-26 r3841 [x86_64-linux-3.13.0-24-generic] (local build)
Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Model Family: Intel 520 Series SSDs
Device Model: INTEL SSDSC2CW480A3
Serial Number: CVCV2060028N480DGN
LU WWN Device Id: 5 001517 bb2841cb5
Firmware Version: 400i
User Capacity: 480,103,981,056 bytes [480 GB]
Sector Size: 512 bytes logical/physical
Rotation Rate: Solid State Device
Device is: In smartctl database [for details use: -P show]
ATA Version is: ACS-2 T13/2015-D revision 3
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Fri Oct 3 15:23:32 2014 BRT
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 1048) seconds.
capabilities: (0x7f) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Abort Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: ( 48) minutes.
Conveyance self-test routine
recommended polling time: ( 2) minutes.
SCT capabilities: (0x0021) SCT Status supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 10
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
5 Reallocated_Sector_Ct 0x0032 100 100 000 Old_age Always - 0
9 Power_On_Hours_and_Msec 0x0032 000 000 000 Old_age Always - 901366h+01m+56.610s
12 Power_Cycle_Count 0x0032 099 099 000 Old_age Always - 1726
170 Available_Reservd_Space 0x0033 100 100 010 Pre-fail Always - 0
171 Program_Fail_Count 0x0032 100 100 000 Old_age Always - 0
172 Erase_Fail_Count 0x0032 100 100 000 Old_age Always - 0
174 Unexpect_Power_Loss_Ct 0x0032 100 100 000 Old_age Always - 1722
184 End-to-End_Error 0x0033 100 100 090 Pre-fail Always - 0
187 Uncorrectable_Error_Cnt 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 1722
225 Host_Writes_32MiB 0x0032 100 100 000 Old_age Always - 104717
226 Workld_Media_Wear_Indic 0x0032 100 100 000 Old_age Always - 65535
227 Workld_Host_Reads_Perc 0x0032 100 100 000 Old_age Always - 70
228 Workload_Minutes 0x0032 100 100 000 Old_age Always - 65535
232 Available_Reservd_Space 0x0033 100 100 010 Pre-fail Always - 0
233 Media_Wearout_Indicator 0x0032 100 100 000 Old_age Always - 0
241 Host_Writes_32MiB 0x0032 100 100 000 Old_age Always - 104717
242 Host_Reads_32MiB 0x0032 100 100 000 Old_age Always - 249846
249 NAND_Writes_1GiB 0x0013 100 100 000 Pre-fail Always - 4807
SMART Error Log not supported
SMART Self-test Log not supported
SMART Selective self-test log data structure revision number 0
Note: revision number not 1 implies that no selective self-test has ever been run
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
ENeto
Found other complaints about this same 520 Series SSDs here in the community. Seems I just bought a known crappy Intel product with a Sandforce SF-2281 chipset. Known to be a chipset with a crappy firmware even here.
Jose_H_Intel1
Hi edmundo_vn, there are some steps that may help:
I hope the above suggestions help.
ENeto
My BIOS is already the latest one for UX32VD (214).
If you see the link you gave me and the above SMART information, I'm already using 400i firmware since I received the SSD. issdfut_2.0.13.iso don't have any update.
If I do a secure erase will it work inside an USB case and stop powering off/on by its own? Besides loosing 2 or more days of work to reinstall everything and not pretending to mess with the host protected area (that I don't have sure if helps with wear levelling) I don't see the point.
ENeto
And I already TRIM my SSD on every system boot.
Jose_H_Intel1
Besides the usual recommendations, another option is to contact your local http://www.intel.com/p/en_US/support/contactsupport Intel support center for further assistance.
ENeto
This SSD was bought from a local reseller that import products from USA to Brazil. According to him, my SSD don't have more than a year warranty (or he simply don't care about it).
ENeto
As everybody knows about the problems with this drive. Lenovo made a custom firmware LB3i to specific models they sold, HP seems to use that firmware? I readed here http://h20566.www2.hp.com/portal/site/hpsc/template.PAGE/public/kb/docDisplay/?docId=emr_na-c0380994... HP Support document - HP Support Center but its only for drives with 180 or 240GB.
Can anyone comment on this?
http://www.sounddevices.com/notes/video-note/updating-intel-520-firmware/ PIX-SSD5 (Intel 520 Drive) Firmware Update Process | Sound Devices Technical Notes | Sound Devices, LLC
They say this update is for the 480GB drives, but I did not understood if Intel made it to address something specific to their devices.
ENeto
I secure erased my drive (it did not made any difference). But I repartitioned it using MBR and made sure the GPT partition table was erased, some tools can make a mess with both tables. The drive inside an USB case seems to be disconnecting less times now, but it still does.
Jose_H_Intel1
We would like to get as much information from your system as possible in order to investigate the disconnect issue. Kindly provide the motherboard model, processor, BIOS version, memory specifications.
In regards of the "Sound Devices" thread, that was a custom firmware released to solve compatibility issues with their products.
ENeto
$ sudo LANG=en lshw
zenbook-ux32vd
description: Notebook
product: UX32VD (ASUS-NotebookSKU)
vendor: ASUSTeK COMPUTER INC.
version: 1.0
serial: CAN0AS54035743B
width: 64 bits
capabilities: smbios-2.7 dmi-2.7 vsyscall32
configuration: boot=normal chassis=notebook family=UX sku=ASUS-NotebookSKU uuid=71F8E803-25EC-4AAD-A70D-50465DE1F0AB
*-core
description: Motherboard
product: UX32VD
physical id: 0
version: 1.0
serial: BSN12345678901234567
slot: MIDDLE
*-firmware
description: BIOS
vendor: American Megatrends Inc.
physical id: 0
version: UX32VD.214
date: 01/29/2013
capacity: 6080KiB
capabilities: pci upgrade shadowing cdboot bootselect socketedrom edd int13floppy1200 int13floppy720 int13floppy2880 int5printscreen int9keyboard int14serial int17printer acpi usb smartbattery biosbootspecification uefi
*-cache:0
description: L2 cache
physical id: 8
slot: CPU Internal L2
capacity: 512KiB
capabilities: internal write-through unified
*-cache:1
description: L1 cache
physical id: 9
slot: CPU Internal L1
capacity: 128KiB
capabilities: internal write-through data
*-cache:2
description: L3 cache
physical id: a
slot: CPU Internal L3
capacity: 4MiB
capabilities: internal write-back unified
*-memory
description: System Memory
physical id: b
slot: System board or motherboard
*-bank:0
description: SODIMM DDR3 Synchronous 1600 MHz (0.6 ns)
product: 99U5428-053.A00LF
vendor: Kingston
physical id: 0
serial: 162894E5
slot: ChannelA-DIMM0
width: 64 bits
clock: 1600MHz (0.6ns)
*-bank:1
description: DIMM [empty]
product: [Empty]
vendor: [Empty]
physical id: 1
serial: [Empty]
slot: ChannelA-DIMM1
*-bank:2
product: HMT325S6CFR8C-PB
vendor: Hynix/Hyundai
physical id: 2
serial: 00000000
slot: ChannelB-DIMM0
width: 64 bits
*-bank:3
product: [Empty]
vendor: [Empty]
physical id: 3
serial: [Empty]
slot: ChannelB-DIMM1
*-cpu
description: CPU
product: Intel(R) Core(TM) i7-3517U CPU @ 1.90GHz
vendor: Intel Corp.
physical id: c
bus info: cpu@0
version: Intel(R) Core(TM) i7-3517U CPU @ 1.90GHz
slot: SOCKET 0
capacity: 3800MHz
width: 64 bits
clock: 100MHz
capabilities: x86-64 fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush dts acpi mmx fxsr sse sse2 ss ht tm pbe syscall nx rdtscp constant_tsc arch_perfmon pebs bts rep_good nopl xtopology nonstop_tsc aperfmperf eagerfpu pni pclmulqdq dtes64 monitor ds_cpl vmx est tm2 ssse3 cx16 xtpr pdcm pcid sse4_1 sse4_2 x2apic popcnt tsc_deadline_timer aes xsave avx f16c rdrand lahf_lm ida arat epb xsaveopt pln pts dtherm tpr_shadow vnmi flexpriority ept vpid fsgsbase smep erms cpufreq
configuration: cores=2 enabledcores=2 threads=4
*-pci
description: Host bridge
product: 3rd Gen Core processor DRAM Controller
vendor: Intel Corporation
physical id: 100
bus info: pci@0000:00:00.0
version: 09
width: 32 bits
clock: 33MHz
*-pci:0
description: PCI bridge
product: Xeon E3-1200 v2/3rd Gen Core processor PCI Express Root Port
physical id: 1
bus info: pci@0000:00:01.0
version: 09
width: 32 bits
clock: 33MHz
capabilities: pci pm msi pciexpress normal_decode bus_master cap_list
configuration: driver=pcieport
resources: irq:42 ioport:e000(size=4096) memory:f6000000-f70fffff ioport:e0000000(size=301989888)
*-display UNCLAIMED
description: 3D controller
product: GF117M [GeForce 610M/710M/820M / GT 620M/625M/630M/720M]
vendor: NVIDIA Corporation
physical id: 0
bus info: pci@0000:01:00.0
version: a1
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list
configuration: latency=0
resources: memory:f6000000-f6ffffff memory:e0000000-efffffff memory:f0000000-f1ffffff ioport:e000(size=128) memory:f7000000-f707ffff
*-display
description: VGA compatible controller
product: 3rd Gen Core processor Graphics Controller
physical id: 2
bus info: pci@0000:00:02.0
version: 09
width: 64 bits
clock: 33MHz
capabilities: msi pm vga_controller bus_master cap_list rom
configuration: driver=i915 latency=0
resources: irq:45 memory:f7400000-f77fffff memory:d0000000-dfffffff ioport:f000(size=64)
*-generic:0 UNCLAIMED
description: Signal processing controller
product: 3rd Gen Core Processor Thermal Subsystem
physical id: 4
bus info: pci@0000:00:04.0
version: 09
width: 64 bits
clock: 33MHz
capabilities: msi pm bus_master cap_list
resources: memory:cfe08000-cfe0ffff
*-usb:0
description: USB controller
product: 7 Series/C210 Series Chipset Family USB xHCI Host Controller
physical id: 14
Jose_H_Intel1
What is the USB case/adapter model your are using with the Intel® SSD?
Did you try a different one by any chance?
ENeto
Yes, tried 3 different cases, one from IT-CEO USB 3, one from IT-CEO USB 2 and one from Western Digital USB 2.
ENeto
Nothing left to do. Intel allowed to issue a RMA. Sending it today.
ENeto
Received another drive from Intel. I did not tested performance as I would need to disassemble my ultrabook again and Im already using a Samsung drive. Tested on another older computer that only supports SATA II and inside an USB case. It doesn't disconnects anymore. Seems to be working as expected.
