Solid State Drives
Support for Issues Related to Intel® Solid State Drives
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
4365 Discussions
Intel® SSD 520 Series [SSD toolbox]
MMimi1
When I launch the Intel SSD Toolbox [version 3.2.3] I get a blue screen.
Intel® SSD 520 Series (120 GB)
Windows 7 professional 64-bit
Asus Rampage 3 gene
I would appreciate any help.
Kevin_M_Intel
Hi Takeda20,
I am sorry you are having this problem but let me help you.
I would like you to try some steps and post your results:
  1. Update the BIOS in your system to latest.
  2. Try installing the latest Intel® Management Engine provided by your Computer Manufacture.
  3. Run the latest SSD firmware update that can be downloaded here:
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=18363&lang=eng&ProdId=3765 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=18363&lang=eng&ProdId=3765
  1. Uninstall completely the toolbox and try downloading/installing it again from this link:
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=18455&lang=eng&ProdId=3765 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=18455&lang=eng&ProdId=3765
Kevin M
MMimi1
Hello Kevin,
1) My BIOS is up to date. Version 1300 (Rampage 3 GENE) .
2) How can I check the version of the Intel® Management Engine?
3) The firmware version of my SSD is 400i (I looked in Device Manager)
Do I need to run the Firmware Update Tool, because 400i is the latest version?
I installed the SSD myself, maybe I messed up some settings?
Thanks for helping me out.
MMimi1
Found this on the Intel forums:
"If ANY drive whatsoever is connected to the Marvell controller (I had a regular HDD connected) then starting SSD Toolbox will give a BSOD 0x3D (no matter where the SSD itself is connected). I guess it happens because the toolbox is trying to ask Marvell for some disk info (god forbid)? The workaround is to disconnect all/any drives from the Marvell 9128 controller (basically the two SATA 3-connections on the motherboard). It's also possible to completely disable it in BIOS."
So it seems to be the Marvell Controller? (I am using the Marvell 9128 Controller.)
Joe_intel suggests to update the Marvell* SATA controller driver. How can I do this? Do I have to reinstall my OS if I change?
Kevin_M_Intel
In this case, in order to update the Marvel Controller you need to contact the manufacture directly for them to provide the latest firmware update.
Kevin M
