Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Intel SSD 520 vrs 710
I seen some good reviews on CNET for the Intel SSD 520 - Went to Intel website and saw there was a 710 available. Hope it is a fair assumption that 710, being the higher number, is an improved version of the 520. Can someone provide what significan differences/improvements (and cost difference) between the two?
Regards, Patric
Community Manager
Hey Patric,
There are a lot of differences between the two SSDs.
The main difference is that the 520's are for use in laptops and desktops.
The 710's are server grade which are designed to be used in servers.
It really depends on what you want the SSD for. If it is for a Desktop/Laptop with a SATA III interface then the 520 is your best bet. Compare the specs of the two SSDs.
Another SSD to consider for Desktop/Laptop use is the 320 if your Desktop/Laptop has a SATA II interface.
Hope this helps
Rodders
Community Manager
The 710 and 520 are very different SSDs. The 710 was introduced before the 520, in Q3-Q4 2011, the 520 Q1 2012. They use different controllers and NAND storage chips, and the 520 is SATA III capable, the 710 SATA II. The 520 is a consumer oriented SSD, the 710 an enterprise (business) SSD. Finally, the 710's price is over three times that of the 520, for somewhat similar capacities.
