cancel
Showing results for
Search instead for
Did you mean:
Intel SSD 530 (180Go) is not detected in bios of recent Asus notebook X751LN (intel chipset) (i precise classic hdd works fine)
DChri2
New Contributor
Any suggestion
6 REPLIES 6
Jose_H_Intel1
Valued Contributor II
Do you know if the laptop and Intel® SSD have the latest firmware?
Thanks for you reply
Yes the laptop and ssd bios/firmware are update, and i precise have 2 identical laptop and many intel ssd (i'm resseler) with no more success.
Jose_H_Intel1
Try connecting the Intel® SSDs to a different system and running a secure erase on them.
You can also do it from Linux* with the instructions given here: http://www.thomas-krenn.com/en/wiki/SSD_Secure_Erase http://www.thomas-krenn.com/en/wiki/SSD_Secure_Erase
This tool can be used to create a bootable USB drive: http://www.pendrivelinux.com/yumi-multiboot-usb-creator/ http://www.pendrivelinux.com/yumi-multiboot-usb-creator/
Hello, you don't understand, the Intel SSD 530 is incompatible with ASUS X751LN notebook.
All parts are news and i realise two test.
All SSD have used for test, are now in other computer and all works fine.
