Community
cancel
Showing results for
Search instead for
Did you mean:
dgret1
Intel SSD 530 not showing on (my computer) but showing up on Devices and printers
Jump to solution
New Intel SSD 530 250gb not showing on my computer but has been detected. I cant load any data, not sure what im doing wrong but im running windows 7 64bit with sabertooth x79 motherboard.
Kevin_M_Intel
Hi david942,
I understand you are having problems with the SSD in the Operating System but let me help you.
If this is a new SSD I recommend you to initialize the device under Disk Management. In the case the SSD has been used, a low level format could do the trick.
Kevin M
Kevin_M_Intel
Hi david942,
Kevin M
