cancel
Showing results for
Search instead for
Did you mean:
Intel SSD 530 on Storage Manager option ROM 8.9.5.1001 PCH-M
MDahl
New Contributor
Our Dell M6500 with Intel Storage Manager option ROM 8.9.5.1001 PCH-M woun´t recognize an Intel SSD 530 Series 120 GB. It is a model SSDSC2BW120A4.
Is there a compatibility problem with this setup or is it supposed to work?
6 REPLIES 6
Jose_H_Intel1
Valued Contributor II
Such option ROM version appears to be old. It may help to update your system BIOS.
Is it possible to identify the SATA controller model? You may type "dxdiag" in Windows*'s Start menu or Run and then click on "Save All Information". The information will appear under "System Devices" in the saved report.
It is also a good idea to check if your system manufacturer has a list of validated SSD models.
This is my intel related system devices:
System Devices
Name: Intel(R) QuickPath Interconnect - D151
Device ID: PCI\VEN_8086&DEV_D151&SUBSYS_00000000&REV_11\3&18D45AA6&0&81
Driver: n/a
Name: Intel(R) 5 Series/3400 Series Chipset Family PCI Express Root Port 6 - 3B4C
Device ID: PCI\VEN_8086&DEV_3B4C&SUBSYS_02EF1028&REV_05\3&18D45AA6&0&E5
Driver: n/a
Name: Intel(R) 5 Series/3400 Series Chipset Family SMBus Controller - 3B30
Device ID: PCI\VEN_8086&DEV_3B30&SUBSYS_02EF1028&REV_05\3&18D45AA6&0&FB
Driver: n/a
Name: Intel(R) QuickPath Interconnect - D150
Device ID: PCI\VEN_8086&DEV_D150&SUBSYS_00000000&REV_11\3&18D45AA6&0&80
Driver: n/a
Name: Intel(R) 5 Series/3400 Series Chipset Family PCI Express Root Port 5 - 3B4A
Device ID: PCI\VEN_8086&DEV_3B4A&SUBSYS_02EF1028&REV_05\3&18D45AA6&0&E4
Driver: n/a
Name: Intel(R) 5 Series 6 Port SATA AHCI Controller
Device ID: PCI\VEN_8086&DEV_3B2F&SUBSYS_02EF1028&REV_05\3&18D45AA6&0&FA
Driver: n/a
Name: Intel(R) processor PCI Express Root Port 1 - D138
Device ID: PCI\VEN_8086&DEV_D138&SUBSYS_02EF1028&REV_11\3&18D45AA6&0&18
Driver: n/a
Name: Intel(R) 5 Series/3400 Series Chipset Family PCI Express Root Port 4 - 3B48
Device ID: PCI\VEN_8086&DEV_3B48&SUBSYS_02EF1028&REV_05\3&18D45AA6&0&E3
Driver: n/a
Name: Intel(R) PM55 Express Chipset LPC Interface Controller - 3B03
Device ID: PCI\VEN_8086&DEV_3B03&SUBSYS_02EF1028&REV_05\3&18D45AA6&0&F8
Driver: n/a
Name: Intel(R) processor DMI - D132
Device ID: PCI\VEN_8086&DEV_D132&SUBSYS_02EF1028&REV_11\3&18D45AA6&0&00
Driver: n/a
Name: Intel(R) 5 Series/3400 Series Chipset Family PCI Express Root Port 3 - 3B46
Device ID: PCI\VEN_8086&DEV_3B46&SUBSYS_02EF1028&REV_05\3&18D45AA6&0&E2
Driver: n/a
Name: Intel(R) processor Miscellaneous Registers - D158
Device ID: PCI\VEN_8086&DEV_D158&SUBSYS_00000000&REV_11\3&18D45AA6&0&43
Driver: n/a
Name: Intel(R) Centrino(R) Ultimate-N 6300 AGN
Device ID: PCI\VEN_8086&DEV_422B&SUBSYS_11218086&REV_35\4&D9B332E&0&00E1
Driver: n/a
Name: Intel(R) 5 Series/3400 Series Chipset Family PCI Express Root Port 2 - 3B44
Device ID: PCI\VEN_8086&DEV_3B44&SUBSYS_02EF1028&REV_05\3&18D45AA6&0&E1
Driver: n/a
Name: Intel(R) 5 Series/3400 Series Chipset Family PCI Express Root Port 1 - 3B42
Device ID: PCI\VEN_8086&DEV_3B42&SUBSYS_02EF1028&REV_05\3&18D45AA6&0&E0
Driver: n/a
Name: Intel(R) 82801 PCI Bridge - 2448
Device ID: PCI\VEN_8086&DEV_2448&SUBSYS_02EF1028&REV_A5\3&18D45AA6&0&F0
Driver: n/a
Name: Intel(R) processor System Control and Status Registers - D157
Device ID: PCI\VEN_8086&DEV_D157&SUBSYS_00000000&REV_11\3&18D45AA6&0&42
Driver: n/a
Name: Intel(R) processor Semaphore and Scratchpad Registers - D156
Device ID: PCI\VEN_8086&DEV_D156&SUBSYS_00000000&REV_11\3&18D45AA6&0&41
Driver: n/a
Name: Intel(R) 5 Series/3400 Series Chipset Family PCI Express Root Port 8 - 3B50
Device ID: PCI\VEN_8086&DEV_3B50&SUBSYS_02EF1028&REV_05\3&18D45AA6&0&E7
Driver: n/a
Name: Intel(R) processor System Management Registers - D155
Device ID: PCI\VEN_8086&DEV_D155&SUBSYS_00000000&REV_11\3&18D45AA6&0&40
Driver: n/a
Name: Intel(R) 5 Series/3400 Series Chipset Family PCI Express Root Port 7 - 3B4E
Device ID: PCI\VEN_8086&DEV_3B4E&SUBSYS_02EF1028&REV_05\3&18D45AA6&0&E6
Driver: n/a
Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\VEN_8086&DEV_3B34&SUBSYS_02EF1028&REV_05\3&18D45AA6&0&E8
Driver: n/a
Dell is also looking into this at L2 support. I have the latest bios.
Jose_H_Intel1
Just to make sure the drive is not defective; did you test it in a different computer?
Yes.
It is two drives and both works in a stationary computer from the same brand. That computer is older than the laptop the drives are not working in.
