Community
cancel
Showing results for
Search instead for
Did you mean:
安鄭
Intel SSD 535 256GB(SSDSC2BW256H601, Firmware:BG21)
I have a problem with my ssd like this:
How could I disable DevSleep?
thx
Community Manager
Hello AnnlAl,
Based on the information from your SSD, we can see that you have the OEM version of the Intel® SSD 535.
From our retail units, we don't have the 256GB version, so most likely you have one from an OEM, this means that the write amplification firmware fix won't work for your disc.
Nestor C
FMook
Here's a link to another thread that contains the download for the tool that disables DevSleep on the 535 series.
/thread/112441 https://communities.intel.com/thread/112441
安鄭
Thx, but it doesn't work for 256GB.
There are no suitable firmware to update.
Community Manager
Hello AnnAl,
Thanks for your reply. SSD firmware updates and fixes hosted in our site work with retail versions of our drives only.
We recommend checking the SSD OEM (Original Equipment Manufacturer) support website for firmware releases. Most OEM versions of Intel® SSD have information on the label indicating who the OEM is. If this is not the case, please check with your vendor.
Eugenio F.
