Intel® Optane™ Solid State Drives
Support for Issues Related to Solid State Drives based on Intel® Optane™ technology, Intel® MAS and Firmware Update Tool
435 Discussions
Intel SSD 545s toolbox Error: RAID array detected
FPath
I Just installed my new Intel SSD 545s Series 256GB Drive and installed the Intel SSD ToolBox Version: 3.4.6 (Latest) Date: 5/31/2017. When I run the SSD Optimizer I recieve the following Error: "Error: RAID array detected. If RAID array not present, reboot and try again". My system is as follows:
Asus Motherboard H110-M D with 6th Gen DC Processor
Microsoft Windows 7 Professional (64-bit) SP1
8GB DDR4-HyperX RAM
SATA mode is AHCI Only
I do not have a RAID configuration.
I tried windows volume Shadow Copy ... but same result
I tried with older ver. Intel SSD ToolBox but result is same.
IntelSSDTDK log also attached...
Message was edited by: Fazal Pathan
Hello FazalP,
Thanks for posting in our forum.
We would like to let you know that this version of the Intel® Solid State Drive Toolbox was released before your drive was launched and most likely it is still not fully compatible.
We will be releasing a new version soon, we can keep you posted over here for you to try and test the latest version.
Nestor C
FPath
Thanks for reply
Waiting for new version..
Hello FazalP,
We would like you to please try the https://downloadcenter.intel.com/download/27130/Intel-Solid-State-Drive-Toolbox latest version which is now available. Please let us know if it worked fine.
Nestor C
FPath
Dear Intel
Thanks for the update
My Problem is solved with new SSD toolbox
One more question is which is the latest firmware ver. for 545s
14b or 002c
as both are mentioned on the intel website
please reply
FPath
Dear Nestor C / Intel
14b or 002c
please reply
Faz....
Hello FazalP,
We are glad to hear that the new Intel® Solid-State Drive Toolbox worked fine now.
About your question with the firmware version of the drive, we would like to let you know that the default version is 14B, but with the latest version of the tool, this one includes the latest version 002C.
Please let us know if you need anything else to provide you support.
Nestor C
FPath
Dear Nestor C /Intel
Thanks for the reply
So please replace 14B to 002 from the SSD Firmware Update ver. page to avoid confussion
warm regards
Hello FazalP,
Thank you for letting us. This has been reported already and it will be changed soon.
Nestor C
