Community
cancel
Showing results for
Search instead for
Did you mean:
WTam1
Intel SSD 730 series reading speed slow !
I just bought a intel 730 series 480gb SSD, after installed into my laptop which is Lenovo Y50, i found that the seq speed for Write around 450MB/s, but the Read speed damn slow, only around 60-80 MB/s May i know what is the problem? I already set up the SATA into AHCI controller.
Jose_H_Intel1
Please use http://www.iometer.org/doc/downloads.html Iometer with a Transfer Request Size of 128K.
XXie5
Could you explain it with more detail?
Jose_H_Intel1
The Intel® SSD 730 Series was designed and optimized for a transfer size of 128 KB.
XXie5
Could you teach me what to do after setting transfer request size of 128? Do I need save or load the profile?
The speed did not change after I added the specifications.
XXie5
Did you fix that problem?
ASouz7
Hello Wei_Qiang,
Sory for the delay in responding your question but here it is. We hope it was helpful
1 step:
2 step
3 Step
4 Step
XXie5
Thanks for your reply. I have solved this problem by uninstalling http://support.lenovo.com/us/en/products/laptops-and-netbooks/lenovo-y-series-laptops/y50-70-noteboo... Intel Rapid Storage Technology Driver. It must be incompatible with the SSD.
