cancel
Showing results for
Search instead for
Did you mean:
Intel SSD 750 Series - VPD access through I2C
DBaye
New Contributor
Does the 750 support accessing the VPD through SMBus address 53h, per the SSD Form Factor Specification?
I am not getting an acknowledge when reading from that address.
1 ACCEPTED SOLUTION
Esteemed Contributor III
Hello Odb,
Thanks for posting in our community. In order to better assist you, we would like to know the following information:
- Form factor (2.5 or 1/2 Height) and capacity of your Intel® SSD 750 Series.
- Operating system is installed on the equipment.- Tool(s) used to run this test.- Reason why you need these details. Best regards,Eugenio F.
9 REPLIES 9
Hello Odb,
We haven't heard from you about this post in a few days. Please let us know if we can assist you with anything else.Best regards,Eugenio F.
lli49
New Contributor
We had bought one card of DC P4600, and cannot find VPD capability enabled by PCIe function.
Does that mean we can only achieve the VPD through SMBUS?
Logan
Hello Logan,
Yes, that is correct with the DC P4600 you can only achieve to read the VPD through the SMBUS interface. It is not enabled through the PCIe function.Hope this helps to clarify your question. Best Regards, Juan N.
Hello Logan,
I would like to know if you have any additional question regarding this post.Best Regards, Juan N.
lli49
New Contributor
Hi Juan,
Thanks for your reply, it answered my question.
No more questions.
Best wishes!
Logan
