Community
cancel
Showing results for
Search instead for
Did you mean:
APinn
Intel SSD 750 -Trouble installing driver 1.3.0.1007 over 1.2.1002. I get message "Fatal error during installation"
Hi jonathan_intel,
I have trouble installing driver 1.3.0.1007 over the top of 1.2.1002. I get message "Fatal error during installation"
I have tried all permutations of upgrading or uninstalling 1.2.0.1002 and driver installation utility or manual driver update from device manager.
If your driver gurus will be so kind as to look at my problem I will be very grateful.
I get the following log from IntelNVME.log -
2015:10:28 10:15:05:793:
2015:10:28 10:15:05:793: >>> Log start
2015:10:28 10:15:05:793: Single-instance mutex has been obtained
2015:10:28 10:15:05:793: Core version: 2.5.35
2015:10:28 10:15:05:793: Setup version: 2.0.15.0
2015:10:28 10:15:05:793: Command line: "D:\Intel Windows NVMe driver 1.3.0.1007 x32-x64\Installer\SetupNVME.exe"
2015:10:28 10:15:05:793: OS data: 6-1-1-1 64-bit
2015:10:28 10:15:05:793: System up time: 88 sec
2015:10:28 10:15:05:793: Reboot pending: No
2015:10:28 10:15:05:793: Current UI language: 0409
2015:10:28 10:15:05:793: Language folder: C:\Users\User\AppData\Local\Temp\IIF59A3.tmp
2015:10:28 10:15:05:809: Found C:\Users\User\AppData\Local\Temp\IIF59A3.tmp\en-US\IntelCommon.dll. Lang 0409. Rank 3
2015:10:28 10:15:05:809: Loading language 0409
2015:10:28 10:15:05:809: Setup mode: Update
2015:10:28 10:15:05:809: Looking for OS: 6.0.3 6.1 6.2 6.3 10.0
2015:10:28 10:15:05:809: OS check passed
2015:10:28 10:15:05:809: .NET not required, skipping requirement check
2015:10:28 10:15:05:809: Resolving driver source
2015:10:28 10:15:05:809: Using embedded driver(s). Temp source is 'C:\Users\User\AppData\Local\Temp\IIF59B4.tmp'
2015:10:28 10:15:05:809: Using folder 'C:\Users\User\AppData\Local\Temp\IIF59B4.tmp' as the driver source
2015:10:28 10:15:05:809: Scanning all active devices
2015:10:28 10:15:05:824: Scanning x64\IaNVMe.inf (Name: NVMe, Version: 1.3.0.1007)
2015:10:28 10:15:05:824: Section with the best match: INTEL_NVME.NTamd64.6.1
2015:10:28 10:15:05:824: Device: PCI\VEN_8086&DEV_0953 (Intel(R) Solid-State Drive P3700/P3600/P3500/750 Series)
2015:10:28 10:15:05:840: Matched with: PCI\VEN_8086&DEV_0953&SUBSYS_370D8086&REV_01
2015:10:28 10:15:05:840: Current driver: oem36.inf
2015:10:28 10:15:05:840: Name: NVMe, Provider: Intel, Version: 1.2.0.1002, Section: nvme_inst
2015:10:28 10:15:05:840: MUP OS bits: 0xFFE00
2015:10:28 10:15:05:840: Scanning x86\IaNVMe.inf (Name: NVMe, Version: 1.3.0.1007)
2015:10:28 10:15:05:840: Section with the best match: INTEL_NVME.NTamd64.6.1
2015:10:28 10:15:05:840: Device: PCI\VEN_8086&DEV_0953 (Intel(R) Solid-State Drive P3700/P3600/P3500/750 Series)
2015:10:28 10:15:05:840: Creating properties for all matching INF's
2015:10:28 10:15:05:840: Architecture supported: x86
2015:10:28 10:15:05:840: Architecture supported: x64
2015:10:28 10:15:05:840: Package folder is C:\Users\User\AppData\Local\Temp\IIF59D4.tmp
2015:10:28 10:15:05:855: Package information;
2015:10:28 10:15:05:855: Type MSI: ID='{8cd980b8-2d1b-4444-bb80-9f44a6027623}', Installed version: 1.0.0.0, Extracted: Yes
2015:10:28 10:15:05:855: Preparing UI
2015:10:28 10:15:05:855: Reading storyboard
2015:10:28 10:15:05:855: Page count: 7
2015:10:28 10:15:05:855: Added: Welcome
2015:10:28 10:15:05:855: Added: Modify
2015:10:28 10:15:05:855: Added: License
2015:10:28 10:15:05:855: Added: Confirm
2015:10:28 10:15:05:855: Added: Progress
2015:10:28 10:15:05:855: Added: Finish
2015:10:28 10:15:05:855: Added: Error
2015:10:28 10:15:05:855: Reading string map
2015:10:28 10:15:05:855: No string map present
2015:10:28 10:15:05:871: Showing page: Welcome
2015:10:28 10:15:07:275: Showing page: License
2015:10:28 10:15:09:677: Showing page: Confirm
2015:10:28 10:15:10:832: Setup thread started
2015:10:28 10:15:10:832: Showing page: Progress
2015:10:28 10:15:14:545: Beginning transaction ID=1
2015:10:28 10:15:14:545: Installing 'NVME_x64.msi'
2015:10:28 10:15:14:545: Properties 'PRODUCTFOLDER="C:\Program Files\Intel\Intel(R) NVME Miniport and Filter Device Management" REBOOT=ReallySuppress REINSTALLMODE=dmus'
2015:10:28 10:15:14:545: Setting MSI log file to 'IntelNVME_MSI.log'. Verbosity level is 4096
2015:10:28 10:15:17:555: Return code: 1603
2015:10:28 10:15:17:555: W Aborting install
2015:10:28 10:15:17:633: Transaction complete. Overall return code is 1603
2015:10:28 10:15:17:633: Showing page: Error
2015:10:28 10:15:43:608: Link: Launching 'C:\Users\User\Intel\Logs'
2015:10:28 10:23:53:745: Dumping properties (27 total)
2015:10:28 10:23:53:760: IIF_MSILOGLEVEL=4096
2015:10:28 10:23:53:760: IIF_LOGFOLDER=C:\Users\User\Intel\Logs
2015:10:28 10:23:53:760: IIF_SETUPVERSION=2.0.15.0
2015:10:28 10:23:53:760: IIF_PACKAGEVERSION=1.3.0.1007
2015:10:28 10:23:53:760: IIF_SETUPPATH=D:\Intel Windows NVMe driver 1.3.0.1007 x32-x64\Installer
2015:10:28 10:23:53:760: IIF_CACHELOC=C:\ProgramData\Intel\Package Cache\{d4adb5bf-1030-4537-9954-799459207933}
2015:10:28 10:23:53:760: IIF_OS=6.1
2015:10:28 10:23:53:760: IIF_OSSERVICEPACK=1
2015:10:28 10:23:53:760: IIF_IS64=1
2015:10:28 10:23:53:760: IIF_NET20=1
2015:10:28 10:23:53:760: IIF_NET30=1
2015:10:28 10:23:53:760: IIF_NET35=1
2015:10:28 10:23:53:760: IIF_NET40CLIENT=1
2015:10:28 10:23:53:760: IIF_NET40FULL=1
2015:10:28 10:23:53:760: IIF_NET45CLIENT=1
2015:10:28 10:23:53:776: IIF_NET45FULL=1
2015:10:28 10:23:53:776: IIF_INSTALLEDPACKAGEVERSION=1.0.0.0
2015:10:28 10:23:53:776: IIF_INSTALLFOLDER=C:\Program Files\Intel\Intel(R) NVME Miniport and Filter Device Management
2015:10:28 10:23:53:776: IIF_LANGCOUNTRY=en-US
2015:10:28 10:23:53:776: _INF_NVMe_VERSION=1.3.0.1007
2015:10:28 10:23:53:776: IIF_RESOURCEFOLDER=C:\Users\User\AppData\Local\Temp\IIF59A3.tmp
2015:10:28 10:23:53:776: IIF_SETUPMODE=UPDATE
2015:10:28 10:23:53:776: IIF_PACKAGEPATH=C:\Users\User\AppData\Local\Temp\IIF59D4.tmp
2015:10:28 10:23:53:776: IIF_LICENSE=
2015:10:28 10:23:53:776: IIF_ACCEPTED=1
2015:10:28 10:23:53:776: IIF_EXITCODE=1602
2015:10:28 10:23:53:776: IIF_README=
2015:10:28 10:...
jbenavides
Hello OC_Freak,
We have branched your question to a new thread, since the issue is different from the original one mentioned in the other forum.
jbenavides
Please try the following actions as they have helped to other users in similar scenarios:
- https://downloadcenter.intel.com/download/23929/Intel-Solid-State-Drive-Data-Center-Family-for-NVMe-... Download Intel® Solid-State Drive Data Center Family for NVMe Drivers, 1.3.0.1007 again to discard a corrupted installer.
- Reboot the PC and try the installation again.
- Disable Antivirus software, and any other software that may be accessing/scanning the drive at the time of driver installation.
If the issue persists, we will need more information: Motherboard brand and model, SSD model (2.5 inch or AiC), OS version, is this the boot drive? or is it a data drive?
APinn
Hello jonathan_intel,
"issue persists"...
Motherboard brand and model: Asrock H97M-ITX/ac
BIOS Manufacturer: American Megatrends
BIOS Date: 07/27/2015
BIOS Version: P1.80
CPU: i7-5775C
RAM: 16GB
Boot Drive (C:) : 2 x Samsung 850 Pro 256GB in RAID 0 using Intel RST
Operating System: Microsoft Windows 7 Ultimate (x64) Build 7601
Service Pack: Service Pack 1 (with all windows updates applied)
Anti Virus: Norton Internet Security (Version: 22.5.4.24)
Intel Solid-State Drive, 750 Series, 400GB data drive I:
Date of Manufacture: 01AUG2015
Product Code: SSDPEDMW400G4R5
Version# : H56036-300
S/N: CVCQ53120009400AGN
2015:10:31 10:12:09:409:
2015:10:31 10:12:09:424: >>> Log start
2015:10:31 10:12:09:424: Single-instance mutex has been obtained
2015:10:31 10:12:09:424: Core version: 2.5.35
2015:10:31 10:12:09:424: Setup version: 2.0.15.0
2015:10:31 10:12:09:424: Command line: "D:\Intel Windows NVMe driver 1.3.0.1007 x32-x64_test\Installer\SetupNVME.exe"
2015:10:31 10:12:09:424: OS data: 6-1-1-1 64-bit
2015:10:31 10:12:09:424: System up time: 136 sec
2015:10:31 10:12:09:424: Reboot pending: No
2015:10:31 10:12:09:424: Current UI language: 0409
2015:10:31 10:12:09:424: Language folder: C:\Users\User\AppData\Local\Temp\IIF13BE.tmp
2015:10:31 10:12:09:440: Found C:\Users\User\AppData\Local\Temp\IIF13BE.tmp\en-US\IntelCommon.dll. Lang 0409. Rank 3
2015:10:31 10:12:09:455: Loading language 0409
2015:10:31 10:12:09:455: Setup mode: Update
2015:10:31 10:12:09:455: Looking for OS: 6.0.3 6.1 6.2 6.3 10.0
2015:10:31 10:12:09:455: OS check passed
2015:10:31 10:12:09:455: .NET not required, skipping requirement check
2015:10:31 10:12:09:455: Resolving driver source
2015:10:31 10:12:09:455: Using embedded driver(s). Temp source is 'C:\Users\User\AppData\Local\Temp\IIF13DE.tmp'
2015:10:31 10:12:09:471: Using folder 'C:\Users\User\AppData\Local\Temp\IIF13DE.tmp' as the driver source
2015:10:31 10:12:09:471: Scanning all active devices
2015:10:31 10:12:09:487: Scanning x64\IaNVMe.inf (Name: NVMe, Version: 1.3.0.1007)
2015:10:31 10:12:09:487: Section with the best match: INTEL_NVME.NTamd64.6.1
2015:10:31 10:12:09:487: Device: PCI\VEN_8086&DEV_0953 (Intel(R) Solid-State Drive P3700/P3600/P3500/750 Series)
2015:10:31 10:12:09:502: Matched with: PCI\VEN_8086&DEV_0953&SUBSYS_370D8086&REV_01
2015:10:31 10:12:09:502: Current driver: oem36.inf
2015:10:31 10:12:09:502: Name: NVMe, Provider: Intel, Version: 1.2.0.1002, Section: nvme_inst
2015:10:31 10:12:09:502: MUP OS bits: 0xFFE00
2015:10:31 10:12:09:502: Scanning x86\IaNVMe.inf (Name: NVMe, Version: 1.3.0.1007)
2015:10:31 10:12:09:502: Section with the best match: INTEL_NVME.NTamd64.6.1
2015:10:31 10:12:09:502: Device: PCI\VEN_8086&DEV_0953 (Intel(R) Solid-State Drive P3700/P3600/P3500/750 Series)
2015:10:31 10:12:09:518: Matched with: PCI\VEN_8086&DEV_0953&SUBSYS_370D8086&REV_01
2015:10:31 10:12:09:518: Current driver: oem36.inf
2015:10:31 10:12:09:518: Name: NVMe, Provider: Intel, Version: 1.2.0.1002, Section: nvme_inst
2015:10:31 10:12:09:518: MUP OS bits: 0xFFE00
2015:10:31 10:12:09:518: Creating properties for all matching INF's
2015:10:31 10:12:09:518: Architecture supported: x86
2015:10:31 10:12:09:518: Architecture supported: x64
2015:10:31 10:12:09:518: Package folder is C:\Users\User\AppData\Local\Temp\IIF141E.tmp
2015:10:31 10:12:09:533: Package information;
2015:10:31 10:12:09:533: Type MSI: ID='{8cd980b8-2d1b-4444-bb80-9f44a6027623}', Installed version: 1.0.0.0, Extracted: Yes
2015:10:31 10:12:09:533: Preparing UI
2015:10:31 10:12:09:533: Reading storyboard
2015:10:31 10:12:09:533: Page count: 7
2015:10:31 10:12:09:533: Added: Welcome
2015:10:31 10:12:09:533: Added: Modify
2015:10:31 10:12:09:533: Added: License
2015:10:31 10:12:09:533: Added: Confirm
2015:10:31 10:12:09:533: Added: Progress
2015:10:31 10:12:09:533: Added: Finish
2015:10:31 10:12:09:533: Added: Error
2015:10:31 10:12:09:533: Reading string map
2015:10:31 10:12:09:533: No string map present
2015:10:31 10:12:09:549: Showing page: Welcome
2015:10:31 10:12:11:047: Showing page: License
2015:10:31 10:12:13:324: Showing page: Confirm
2015:10:31 10:12:14:291: Setup thread started
2015:10:31 10:12:14:307: Showing page: Progress
2015:10:31 10:12:18:160: Beginning transaction ID=1
2015:10:31 10:12:18:160: Installing 'NVME_x64.msi'
2015:10:31 10:12:18:160: Properties 'PRODUCTFOLDER="C:\Program Files\Intel\Intel(R) NVME Miniport and Filter Device Management" REBOOT=ReallySuppress REINSTALLMODE=dmus'
2015:10:31 10:12:18:160: Setting MSI log file to 'IntelNVME_MSI.log'. Verbosity level is 4096
2015:10:31 10:12:35:741: Return code: 1603
2015:10:31 10:12:35:741: W Aborting install
2015:10:31 10:12:35:804: Transaction complete. Overall return code is 1603
2015:10:31 10:12:35:804: Showing page: Error
2015:10:31 10:14:11:026: Link: Launching 'C:\Users\User\Intel\Logs'
log from IntelNVME_MSI.log
=== Verbose logging started: 10/31/2015 10:12:18 Build type: SHIP UNICODE 5.00.7601.00 Calling process: D:\Intel Windows NVMe driver 1.3.0.1007 x32-x64_test\Installer\SetupNVME.exe ===
MSI (c) (EC:6C) [10:12:18:160]: Resetting cached policy values
MSI (c) (EC:6C) [10:12:18:160]: Machine policy value 'Debug' is 0
MSI (c) (EC:6C) [10:12:18:160]: ******* RunEngine:
******* Product: C:\Users\User\AppData\Local\Temp\IIF141E.tmp\NVME_x64.msi
******* Action:
******* CommandLine: **********
MSI (c) (EC:6C) [10:12:1...
jbenavides
Hello OC_Freak,
Please apply the following actions to remove the driver completely, then install the new one:
- Back up any important data that you may have in the SSD (best practice before this type of actions)
- Save the Intel® Solid-State Drive Data Center Family for NVMe Drivers to a location in your boot drive, or a removable media.
- Go to Windows* Device manager, Storage Controllers, right click the 750 SSD and select "uninstall", Make sure you mark the option to "Delete the driver software for this device".
- Reboot the PC or scan for hardware changes, check device manager again and if an older driver is installed, repeat the actions to uninstall and delete it.
- Install the latest Intel® Solid-State Drive Data Center Family for NVMe Drivers that you downloaded before.
APinn
I followed your instructions as above precisely, however, the Intel® Solid-State Drive Data Center Family for NVMe Drivers GUI gave me the same error message, as above.
The good news is that in Device manager, "PCI device" showed up after the 750 SSD disappeared from Storage Controllers.
I uninstalled "PCI device" a few times and did a re-boot and uninstalled "PCI device" again a few times, it kept coming back showing no drivers installed.
I then, under device properties, clicked "Update Driver" button and browsed to the "Driver64" folder of the Intel® Solid-State Drive Data Center Family for NVMe Drivers,
named (on my machine) "Intel Windows NVMe driver 1.3.0.1007 x32-x64_test".
The driver then installed correctly :-) .
Thank you,
OC_Freak.
