Community
cancel
Showing results for
Search instead for
Did you mean:
PDhar
Intel SSD DC P3600 Series drive goes to disable logical state after reboot.
I was using around 6 NVMe drives in my test system and after a reboot 4 out of 6 drives entered to disable logical state. For one of the isdct show displays the drive status as "
DeviceStatus: *XASSERT_40344698 ZK". The firmware version in the drive is 8DV10110. Now at this logical failed state I couldnt fetch any other details (like logs) and the other failed drives also show similar symptom, any help i appreciated. Thanks
jbenavides
Hello PDSP,
Please provide some additional details so we can have a better understanding of the issue:
- Computer brand and model
- Motherboard brand and model
- Operating System version (including 32 or 64 bit)
- CPU
- BIOS & EFI version
- NVME driver version
- Model of the SSD's (size, 2.5" or AiC form factor, model number)
- Slot type where the drives are connected (PCIe slot 2.0 or 3.0, SFF-8639 backplane, etc)
- Are you booting from an NVMe drive?
- What type of test or tasks were you running before the issue appeared?
- Did this happen after a soft reboot, or was it a power removal during activity?
PDhar
Hi Jonathan,
Please find my answers inline.
Vendor_id: GenuineIntel
Model: Intel(R) Xeon(R) CPU E5-2620 0 @ 2.00GHZ
Manufactures: Intel
Product Name: S2600IP
Version: G20993-303
CentOS 7.1 with latest stable kernel version 4.0.5
- CPU
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
CPU(s): 12
On-line CPU(s) list: 0-11
Thread(s) per core: 2
Core(s) per socket: 6
Socket(s): 1
NUMA node(s): 1
Vendor ID: GenuineIntel
CPU family: 6
Model: 45
Model name: Intel(R) Xeon(R) CPU E5-2620 0 @ 2.00GHz
Stepping: 7
CPU MHz: 2447.421
BogoMIPS: 3990.49
Virtualization: VT-x
L1d cache: 32K
L1i cache: 32K
L2 cache: 256K
L3 cache: 15360K
NUMA node0 CPU(s): 0-11
system bios version 2.14.1219
SMBIOS 2.6 present.
Handle 0x0000, DMI type 0, 24 bytes
BIOS Information
Vendor: Intel Corp.
Version: SE5C600.86B.02.02.0002.122320131210
Release Date: 12/23/2013
Address: 0xF0000
Runtime Size: 64 kB
ROM Size: 8192 kB
Characteristics:
PCI is supported
BIOS is upgradeable
BIOS shadowing is allowed
Boot from CD is supported
Selectable boot is supported
EDD is supported
5.25"/1.2 MB floppy services are supported (int 13h)
3.5"/720 kB floppy services are supported (int 13h)
3.5"/2.88 MB floppy services are supported (int 13h)
Print screen service is supported (int 5h)
8042 keyboard services are supported (int 9h)
Serial services are supported (int 14h)
Printer services are supported (int 17h)
ACPI is supported
USB legacy is supported
BIOS boot specification is supported
Targeted content distribution is supported
BIOS Revision: 4.6
version: 1.0 (found this using modinfo nvme)
Model: SSDPE2ME400G4
2.5" NVMe/PCIe SSD 400G
SN: XXXXXX (Removed by moderator)
Intel SSD DC P3600 Series 400GB
PLX switch
No, I have an intel controller where the OS drive is attached to.
Issued a format command for one of the drive. Used this command for formatting "isdct start -intelssd 0 Function=nvmeformat LBAFormat=0 SecureEraseSetting=0 ProtectionInformation=0 MetadataSetting=0"
Did a reboot after completing the format command.
After a soft reboot
Thanks for your help.
jbenavides
Hello PDSP,
We reviewed the information you have provided, and this will be better handled through a ticket with the http://www.intel.com/p/en_US/support/contactsupport Support Center.
Please check your private messages for more details.
