i need upgrade many industrial PC´s with classic sata (512b not advanced format) harddrive. Installing OS is WinXP.
I use for data transmission cloning SW Acronis True image. (I have create images)
I have 2 questions:
1. You need install Acronis AlignTool - Intel SSD Edition on PC after upgarade?
(on this PC is not possible installing another SW)
2. Stored data on HDD(SSD) will read in another PC. Is AES-256 crypting enable or disable from manufactory?
(When is crypting enable, how can i disable it?)
Thanks a lot
Acronis AlignTool* - Intel® SSD Edition could be used if there are performance issues caused by misalignment of sectors and clusters after installing Windows* XP. You may want to verify if the partition is correctly aligned in order to determine if you need to install this tool; some web pages provide good recommendations about this topic, such as the one below.
http://lifehacker.com/5837769/make-sure-your-partitions-are-correctly-aligned-for-optimal-solid-stat... http://lifehacker.com/5837769/make-sure-your-partitions-are-correctly-aligned-for-optimal-solid-stat...
Encryption on Intel® SSDs is ready to be used (on supported models); you just need to set up the Hard Drive password in BIOS. The following link may be of further help: /message/212662# 212662 https://communities.intel.com/message/212662# 212662
