Community
cancel
Showing results for
Search instead for
Did you mean:
JJuli5
Intel SSD DC S3700 SED
Intel SSD DC S3700 SED-is there a way to remove self encryption feature or decrypt SED?.. The self encryption feature is preventing us from doing a firmware based secured erase after decomissioning the the hardware. HPDL380 G8
Community Manager
Hello JulioJ,
We understand you need to remove the SED in order to perform a firmware based secure erase. Could you share a screenshot of this situation?
Do you have an actual error message?
There is no way to remove the feature since this is done at the drive level and it basically helps to prevent unwanted intrusion and secure the drive.
NC
JJuli5
Community Manager
Hello JulioJ,
After reviewing the case, we can only suggest to try to run secure erase using HDparm in Linux:
hdparm --user-master master --security-set-pass password /dev/sdX
hdparm --user-master master --security-erase password /dev/sdX
hdparm -Np468862128 /dev/sdX
Here is a http://www.intel.com/content/dam/www/public/us/en/documents/white-papers/ssd-server-storage-applicat... link with more information about it.
Let us know if this helps.
NC
Community Manager
Hello JulioJ,
We would like to know if you were able to follow the previous instructions or if you still require further assistance. We will be waiting for your response.
NC
