Solid State Drives
Support for Issues Related to Intel® Solid State Drives
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
4365 Discussions
Intel SSD M2 with Intel RST Premium
blanc-sanglier
I have an Asus Prime B565M-A motherboard running the Intel B365 chipset fitted with two Intel 660p series 1TB M.2 NVMe SSDs on board.  My aim is to get this up running as a RAID1 (mirroring) system.
I get a problem when I set the SATA mode on the motherboard to 'Intel RST Premium With Intel Optane System Acceleration (RAID)'. I boot into set up from a Windows 10 usb  drive and get to the Windows set up screens. I then try and install the O/S on the M.2 drive and Windows objects saying this is is not a bootable disc. If I change the SATA mode to the Advanced Host Controller Interface (ACHI), Windows installs on the M.2 drive without problem.
Any ideas as to what i am doing wrong?
thnx. bill
blanc-sanglier
LeonWaksman
Hi @blanc-sanglier
Please follow the Asus guide for RAID installation.
Leon
n_scott_pearson
Super User Retired Employee
It says it is not a bootable disk because it does not have the device drivers that would indicate so. When installing Windows, when you get to the scene where you are selecting the drive and partition to install Windows onto, you need to load the intel RST drivers. This is the F6FLPY.ZIP file that you see in the list of downloads for RST (and Optane).
blanc-sanglier
thnx scott, i think i understand what i have got to do now. will try it out next week. bill
blanc-sanglier
Hi Scott
All sorted now. FYI I used the Intel drivers from the Asus site rather than the Inte site for safety.  Thanks a loy for the steer. bill
blanc-sanglier
Thanx Leon, I've had a quick read and I think i understand the process now. will give it a try next week. bill
blanc-sanglier
Vegan
I suggest using the SSD discretely and get a hard disk and use it for backups. Backup disks in a desktop rig make it easier when Windows needs to be repaired or reset.
blanc-sanglier
thnx Vegan, thanks for the advice. i really want to set up RAID1 but i am using an onboard hdd and a NAS (hdd) for backup so i am hopefully covered belt & braces. bill
Vegan
windows 10 file history can use a secondary hard disk for fault tolerance. Its one option.
I use 7-zip and make wholesale backups to removable disks. I have a USB cable and old laptop disks make for a handy backup device.
blanc-sanglier
Hi Vegan - i am up and running and it's all tickety boo. thnx bill
