Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Intel SSD Optimizer can't Run
I just installed the new Toolbox 2.0 to run the optimizer on my G2, but it fails everytime and says "Error creating Intel SSD Optimizer files on the selected drive". I got the same problem with 1.3 and couldn't solve it.
That's why I used still 1.2.
Hopefully anyone knows where the problem is.....
OS is Win7 64bit
Community Manager
Is it possibly the Win7 utility that stops non-signed programs from running? I think you can check for a list of programs that have been denied permission to run?
Community Manager
Mine wont run either. Going back to the 1.3 that was running well from the moment I installed it to the moment I uninstalled it. This new one keeps saying I have a raid drive, I have a 160g2 (X25-M Solid State Drive, 160GB SATA II ) and a Seagate 2 tb running. No raid.
Community Manager
Right click on the installer program and try running as administrator.
Community Manager
I installed it correctly. It just comes back with an error indicating that it cant be run on raid which is not my case.
In case it is useful the following is the output from crystaldiskinfo
CrystalDiskInfo 3.5.6 (C) 2008-2010 hiyohiyo
Crystal Dew World : http://crystalmark.info/
OS : Windows 7 Ultimate Edition [6.1 Build 7600] (x64)
Date : 2010/09/13 15:36:58
-- Controller Map ----------------------------------------------------------
+ AMD SATA Controller [ATA]
- ST320006 41AS SATA Disk Device
- INTEL SS DSA2M160G2GC SATA Disk Device
+ Standard Dual Channel PCI IDE Controller [ATA]
+ ATA Channel 0 (0)
- HL-DT-ST BD-RE WH10LS30 ATA Device
- ATA Channel 1 (1)
-- Disk List ---------------------------------------------------------------
(1) ST32000641AS : 2000.3 GB [0-X-X, pd1]
(2) INTEL SSDSA2M160G2GC : 160.0 GB [1-0-0, pd1] - il
(1) ST32000641AS
Model : ST32000641AS
Firmware : CC13
Serial Number : 9WM089LM
Disk Size : 2000.3 GB (8.4/137.4/2000.3)
Buffer Size : Unknown
Queue Depth : 32
# of Sectors : 3907020911
Rotation Rate : 7200 RPM
Interface : Serial ATA
Major Version : ATA8-ACS
Minor Version : ATA8-ACS version 4
<span style="mso-ansi-language: ES; mso-spacerun...
Community Manager
I was replying to Apophis.
It might be better to start your own thread, as answers will get mixed-up and nobody will resolve hid/her issues.
Community Manager
Ok I solved my Problem, but I still don't know what caused it.
It was definitley no Anti-Virus Programm or Firewall. I started the Toolbox as Admin and turned my Kaspersky off.
Anyway I desperatly (:D) decided to erase my system and to reinstall everything and now it's working fine o.O
I supppose that there was a conflict somewhere in on my "old" system.
Thanks anyway
