Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Intel SSD Optimizer failed - XM25-M 80Gb in XP Pro SP3
I ran the Full Diagnostic Scan and the SSD checks out fine.
However, when I ran the SSD Optimizer, it turned blue to red and status indicates the process has failed.
I am on Toolbox version 1.3.0.000
Community Manager
Windows XP any verison (except XP 64 bit), has a known problem SSD drives, SD cards in NTFS file format. Thats why you can not format an SD Card to NTFS in XP. ONLY FAT 32
I format my stuff on a Vista or 7 system then use it in XP.
I'm guessing this is one way Microsoft's is making us buy a new OS. (lol)
Unless we all complain!!!!!! Microsoft won't make a hot fix
Community Manager
Is this really true, Intel?
I still await the solution to this problem. I am still not giving up on my XM25 just yet.
Community Manager
I read about this on several forums even Dells and Viliv.
Some just format the SSD in Fat32 and some bought XP 64bit which seems to have no problems.
mmokk
New Contributor II
32-bit windows xp pro sp3 formats ssd's to ntfs just fine. i've done it many times.
Community Manager
Curious, why "many times" are you getting hard drive lock ups or corrupt data like some pepole are experiencing?
Just to be clear! Some do not have any problems at all.
mmokk
New Contributor II
i haven't had any problems at all. this is on quite a variety of ssd's, not just intels.
you claimed that there was a 'known issue' specifically with xp pro sp3 formatting ssd's to ntfs, but you did not explain in detail what that was, or provide links.
Community Manager
Before I purchased the X25 M 160 gigs I did a little research on price and tech data, and I came across a few blogs and forums where pepole are having problems with XP and any SSDs I did not make a case out of this just wanted to share my findings. I am sure you can google it.
When my X25-M comes from Newegg I'll give feed back on my experience in a few weeks.
mmokk
New Contributor II
yes, i did google it, and found nothing indicating that xp pro has a 'known issue' with formatting ssd's to ntfs. i do find that many users don't really know what they're doing and wrongly blame the ssd when the real cause of the problem is themselves or platform/bios compatibility issues. this isn't to say that ssd's are immune to data corruption or failure (and in that respect you should treat them as you would any storage device, i.e. they can fail at any time, so back up any important data).
Community Manager
I couldn't agree more with you! Many people do not use their computers properly and always blame it on everything but them selves.
That's why I'll wait till I play with it on my own.
I think I did find most of the issuse on Dell's Support forums for the Minis.
Community Manager
Well, is there a solution to this?
error creating intel ssd optimizer files on the selected drive - this error message is still happening...
Community Manager
WHAT IS HAPPENING, INTEL????
