Solid State Drives
Support for Issues Related to Intel® Solid State Drives
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
4365 Discussions
Intel SSD Pro 1500, 240GB can not be formatted
Community Manager
Hello, I have an SSD Pro 1500 with 240GB, the disk is recognized by the computer, but the existing partition is not formatted, it can not be formatted or deleted. Can you help me?
Best regards Mario
Community Manager
Hello Mario_Eggert,
What we recommend in this case is to try a secure erase on the SSD. For this, you'll need to plug the SSD as a secondary drive to the SATA port and perform a secure erase. (In case you use windows*)
http://www.intel.com/content/www/us/en/support/memory-and-storage/000022179.html Here is a link that can be useful for you to try the secure erase.
Please let us know if it worked.
Nestor C
Community Manager
Unfortunately the secure Erase does not work either. Not with the toolbox, diskpart, or gparted. The ssd always reports an input-output error.
Community Manager
Hello Mario_Eggert,
On that case, we do suggest you contacting our http://www.intel.com/content/www/us/en/support/contact-support.html# @22 support department to get further assistance.
Nestor C
Community Manager
Hello Mario_Eggert,
We would like to know if you were able to contact our support department. We'll be waiting for your response.
Nestor C
atrea
Hi Mario_Eggert,
If you can't secure erase the 240GB Intel SSD Pro 1500 in Windows. You'd better to try the third party disk format tool, like AOMEI Partition Assistant, EaseUS Partition Master, MiniTool Partition Wizard, etc. You can http://www.disk-partition.com/articles/format-ssd-6289.html format Intel SSD drive with a few clicks.
Ailsa Treasure
Community Manager
Hi Ailsa,
Thanks for the feedback.
@Mario_Eggert, you can try those tools as well or contact us
Nestor C
RFroh1
I think I have the same problem. You can read my progress at this link. Was there a solution to this issue from support?
Rob
ppara5
Valued Contributor I
One of the things that often works is a complete disk wipe using either the shred (sudo shred -vn 1 /dev/sdX) or dd (sudo dd if=/dev/zero of=/dev/sdX) commands in Linux. The OP mentioned GParted, so he was at least somewhat familiar with Linux. DBAN is a free disk wipe recommended by Intel for recalcitrant SSDs and uses either shred or dd to do its work (it easily fits on a CD-R). Just note that shred, dd, or DBAN will be like writing the capacity of the drive, in other words, it's a last resort. And by the way, Linux can be used via LiveUSB or LiveCD to do the above. All that said, it's my experience that SSDs or USB flash drives reporting an input-output error are usually toast.
Laptop_Gaming_Cũ_TPH
Can you take a picture as a format? So people will easily help you!
