Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Intel SSD Toolbox 3.4.3 show exlamation mark on Firmware Update but does not allow to update
Jump to solution
SSD Toolbox does not allow run optimizer (possible) due not updated firmware but does not allow to update it - update button is gray.
3.4.3 is latest version for now, afaik.
What to do with this?
Tags (1)
Community Manager
Hello Sopholos,
We understand you cannot update the firmware on your SSD and also the optimizer does not work. We have seen this kind of situation before and we can suggest to you to install the https://downloadcenter.intel.com/download/26451/Intel-SSD-Data-Center-Family-for-NVMe-Drivers latest NVMe* driver.
After you install this driver, please restart the computer and then try again. It should work just fine.
Please let us know if this does not work.
Nestor C
Community Manager
Hello Sopholos,
Nestor C
Community Manager
Hello Sopholos,
We would like to know if you tried our previous recommendation and if it worked fine. We'll be waiting for your response.
Nestor C
Community Manager
Sorry for not answering, but I'm currently in other city than computer and could not check. I will check and answer when I can. Thank you for advice.
Community Manager
Hi Sopholos,
Thanks for responding. Please let us know as soon as you can try our suggestion. We'll be waiting for your response.
Nestor C
Community Manager
Hello Sopholos,
We would like to check if you had time to test our previous suggestions, if not, feel free to post them whenever you can.
Nestor C
Community Manager
No. still could not check.
