Solid State Drives
Support for Issues Related to Intel® Solid State Drives
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
4365 Discussions
Intel SSD X25-M G2 80GB: 13 Bad Sectors - a problem?
MBoss
Dear Intel Community:
I ran SMART Utility over my Intel SSD drive yesterday and noticed that 13 bad sectors appeared. Here are the screen shots:
Since this is the only drive in the system (MacOS 10.6.8), I am worried about disk failure. The serial number is visible in image 1.
Thanks a lot,
Magnus
Community Manager
Backup your data and do a secure erase https://ata.wiki.kernel.org/index.php/ATA_Secure_Erase https://ata.wiki.kernel.org/index.php/ATA_Secure_Erase
or just use http://partedmagic.com/ http://partedmagic.com/
The sleep backdoor described in wiki article is functional with parted magic also.
Community Manager
Regularly backing up your data is always good practice. In the overall big picture 13 sectors is not alot as you can see the available reserve space is still sitting at 99%. Your SMART data looks fine. I don't think you have a problem.
