Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Intel SSD on Dell Precision Workstation 670 slow write speed
Jump to solution
Hi, I've decided to purchase the new Intel 320 series 40GB SSD disk as my system drive on Dell Precision Workstation 670.
The problem is that WRITE SPEED on this drive CANNOT EXCEED 50 MB (benchmarked with ATTO). I've been trying different setups; on Win XP Pro x64, Win 7x64, different controllers (on-board CERC and Adaptec 1430SA), using manually adjusted partitions (XP x64), running Intel SSD Toolbox, proceeding recommended optimalisations and NOTHING HELPS.
Bandwidth seems to be cut on certain level, see the atto results.
Read speed is, let's say, satisfying: ~200 MB/s (on 1430SA).
Magic 50 MB/s is not to overleap. If you have experienced similar problem and found the solution please share.
Tags (1)
Community Manager
Intel 320 SSD 40GB 45MB sustained write is according the specifications.
Community Manager
Community Manager
OK. Thank you.
So I'm disappointed a little bit.
The 40GB is not a speed demon as written on attached sticker...
Community Manager
Yup, the numbers are normal. The 40GB model have half the NAND chips and half the channels so write performance is impacted. However, I would not worry about it too much.
Basically, your disk usage breaks down into (order of importance):
Random reads - fine here since read performance is good
Random writes - fine here since small file write performance is good
Sequential read - fine here since read performance is good
Sequential writes - not very important since how often are you writing 100MB+ files to a 40GB SSD?
