Community
cancel
Showing results for
Search instead for
Did you mean:
LTayl5
Intel Smart Response Technology
Hi.....I just install irst 10.6.0.1002 on a Gigabyte Z68 motherboard.I was running 10.5.0.1027 fine before this. Actually the system appears to be running fine at this new level driver.The problem I'm seeing is that after the irst service starts up I get a small irst error box saying I need to install 10.5.0 or higher;and I need to OK the message to make it go away.I beleive it's a false error detected in the service because 10.6.0.1002 is the latest and greatest.Has anyone seen this error or have a solution to it?
MBall5
New Contributor II
Take into consideration that this specific issue is not related with ssd, I suggest you to ask this question at the chipset community support forum
