Community
cancel
Showing results for
Search instead for
Did you mean:
AL5
Intel Smart Response on Windows 8 UEFI
Hey guys, so, I've been stuck on this issue for a while now. I have 3 drives in my system. I have a 2tb hd, which is my system drive, a 500gb hd, an extra storage drive, and a 64gb ssd, which I intended to use for Intel SRT cache on my system drive.
I have Windows 8 installed on a UEFI system with a guid partition table. (GPT) Unfortunately, after installing the OS with the SATA controller in RAID mode, and then installing the IRST drivers, when I go to the performance tab to accelerate my system drive, the dropdown menu only lists the 500gb storage drive as the only acceptable hard drive.
After some quick googling, I think I may have figured out the problem, srt won't work with uefi systems unless you change some stuff around first. I found /thread/45540 this thread as well as /message/138345 this one which states that the problem may be caused by having the os installed by uefi. The second thread actually suggests a fix, by shrinking the drive by a small amount, then extending it back to its regular size. However, this fix did not work for me. Given that both of those threads are quite old, I thought that maybe there now may be a fix for it.
I have an asus Z97-PRO, Windows 8 64-bit UEFI, and the three drives mentioned above.
Does anybody know a fix to this issue?
Jose_H_Intel1
Hi theorange, I recommend you posting in any of the existing threads dealing with the same topic, this way we will concentrate efforts in those discussions.
