Community
cancel
Showing results for
Search instead for
Did you mean:
PVoge1
Intel Solid-State Drive 750 Series 400GB Bios ASUS Z87-WS
Hallo ich habe eine SSD 750 400GB und von ASUS Motherboard Z87-WS und mochte Windows Server 2012 R2 auf die Festplatte Instalieren aber im Bios wird sie zwar angezeigt aber nicht die Bezeichnung und kann das Betriebssystem auch nicht Starten? Konnen sie mir Helfen.
Community Manager
Hi paulluisvogel,
Thank you for contacting our support community. As per our translator tool, we understand your situation regarding the Windows* Server 2012 R2 installation.
We would like to inform you that the Intel® SSD 750 Series is not intended to be in a server environment. We recommend you our https://ark.intel.com/# @DataCenterSSDs Datacenter SSDs Family. However, for the installation process, we recommend you to load the NVMe* driver during the Windows* installation. The reason why you can not see the SSD is that the version of Windows* you are trying to install may not have the inbox NVMe* drivers as Windows* 8.1 or Windows(R) 10 do.
Please follow the next steps:
1-Download the https://downloadcenter.intel.com/downloads/eula/27362/Datacenter-NVMe-Microsoft-Windows-Drivers-for-... 3.2.0.1002-Win32 -Datacenter.zip or the https://downloadcenter.intel.com/downloads/eula/27362/Datacenter-NVMe-Microsoft-Windows-Drivers-for-... 3.2.0.1002-x64 -Datacenter.zip depending on the version you would like to install.
2-Extract the files and load them into a USB.
3-During the Windows* installation, on the option that asks for "where do you want to install Windows*?", please select the option that says load driver.
4-Select the Option that says "Browse" in order to locate the drivers in the specific USB you are using.
5-Select the Option that says Intel(R) Solid-State Drive P3700/P3600/P3500/750 Series and hit next.
After that, you would be able to install Windows* Server on your Intel® SSD 750 Series.
Please let us know the outcome of your situation.
Junior M.
Community Manager
Hi paulluisvogel,
We would like to know if you read our previous post. If you have any other questions, we'll be waiting for your response.
Junior M.
