Community
cancel
Showing results for
Search instead for
Did you mean:
OCong
Intel Solid State Drive Data Center S4500 Series
Hi all,
I am investigating the weight proportion of the SSD. I would like to ask about the materials (weight) used for the casing and internal components sizing/weight as I failed to acquire any specific information regarding the model. Thank you in advance.
Community Manager
Hello zicong,
Thanks for posting in our communities. We understand that you're looking for the weight proportion for Intel® SSD DC S4500 Series.
The available material information for this drive can be found at our https://qdms.intel.com/MDDS/MDDSView.aspx?mm=956902 MDDS database. Is this the information you require? If not, can you share the reason why you require these details?
Eugenio F.
OCong
Hi Eugenio,
I wish to compare the Intel SSD with other SSD in terms of mechanical properties and weight differences. Specifically in terms of the casing. Thank you for the swift reply.
Ong Zi Cong
Community Manager
Hello Ong Zi Cong,
Thanks for the clarification.
These details cannot be shared publicly through our communities. We recommend to https://www.intel.com/content/www/us/en/support/contact-support.html contact your local support, they might be able to direct you to this documentation. Please bear in mind that access to this information usually requires non-disclosure agreements between Intel and your company.
Eugenio F.
Community Manager
Hi Eugenio,
Who should I contact to obtain the material specification of the enclosure of SSD S4500 Series? Any required procedures or agreement to go through? Thank you.
ZI Cong
Community Manager
Hi Zi Cong,
As Eugenio explained, you have to contact your local support for additional details about the product information you are interested in. Please follow this link and go to Memory and Storage section: https://www.intel.com/content/www/us/en/support/contact-support.html. Then select Online Service Request and follow the process to submit your request.
Have a nice day.
Diego V.
