Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Intel X25-E Failures
Anyone having problems with X25-E reliability? We bought ten drives and put 8 of them into a RAID array, and over the past month two of them have failed. One could be a fluke, but two out of ten seems like a really high failure rate in a month.
Community Manager
That does seem like an extraordinarily high failure rate. I have had 4 in RAID 0 since shortly after they were released without any problems. I have not seen people posting reviews noting any failures so far. I hope Intel is taking care of you on the warranty.
Community Manager
Can you tell us the serial numbers of failed drives?
Community Manager
Does it Intel chipset based RAID or not?
If yes then /thread/5036?tstart=0 http://communities.intel.com/thread/5036?tstart=0 possible reason of failures
if not I still need the serials
Community Manager
Sent them back to NewEgg already. I have the serial numbers for the other drives in the shipment... might be from the same batch if that would be helpful.
Community Manager
yep if you can, please post it
Community Manager
We used an Adaptec 5805 and the PERC 6i
CVEM915600AE064KGN
CVEM9163004D064KGN
CVEM9136001P064KGN
CVEM916200U2064KGN
CVEM916000M4064KGN
CVEM9160000T064KGN
CVEM9115009R064KGN
CVEM916000F7064KGN
Community Manager
Sorry for delay
Yes it is possible that some drives came from same batch.
Community Manager
This is very interesting, and yet concerning, as we are about to deploy a 15 drive x25 RAID-6 array using a PERC 6/E controller.
Rjdevereux, can you clarify which RAID card the drives were connected to when they failed? Was it the Adaptec 5805, or the PERC 6i?
