Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Intel X25-M 160 GB
Hi all,
I just got a new HP Envy 15 and an Intel X25-m 160 GB. I manually installed the SSD and cloned the original 500GB HDD. Everything was fine until I tried to update the Intel SSD firmware. I downloaded the firmware update tool and made the bootable cd. Yet when I try to update the firmware I get this:
Intel SSD is not attached or is disabled.
If you know an Intel SSD is installed and correctly connected to your system, please contact Intel Customer Support for further assistance at the following website: http://www.intel.com/ssdsupport http://www.intel.com/ssdsupport
So do you have any idea of how I can update the firmware?
DZand
Valued Contributor I
You should connect the Intel SSD to one of the first Intel SATA ports.(port 0 or 1). Then the Firmware installer will find your SSD.
Community Manager
Thank you for your reply.
I connected the SSD to the HP ENVY's motherboard that happens to be the only sata port (and it is RAID0). Then I don't think that the problem.
DZand
That will be a problem, because you will not be able to flash the Firmware into your SSD, if it is connected with a SATA port, which has been set to RAID Mode.
Before you are going to boot off the Firmware CD, you have to disable RAID within the BIOS. If it should not be possible to disable RAID, you have to connect the SSD to a SATA port of another computer just for doing the Firmware flash operation.
Community Manager
This what my Intel Matrix Storage Console shows. It says non-raid???
DZand
Yes.
Community Manager
I'm kind of lost. The SSD is recognized no-raid by the intel matrix storage console but the sata port bios is set to raid, am I right? I also tried the other internal SATA port but it doesn't work as well.
The only chance is to use the externl esata port? If that is the case do I have to disconnet my ssd and connect it externally every time there is a firmware update?
Or should I try a clean installation of windows 7...maybe after that it will recognize it?
Since I cannot modify the bios setting maybe I should wait for a new bios update?
DZand
@ Stefa:
The installation of Win7 or any other OS will not help at all.
Many users with a notebook have a problem to flash the SSD firmware because of the lack of changing the appropriate SATA Controller settings within the BIOS. If your SATA Controllers are automaticly set to RAID Mode without any ability to disable it, your problem is even worse. The fact, that you haven't created a real RAID array, doesn't really help.
Waiting for a BIOS update, which will give you more BIOS settings options, is useless. You probably will never get the needed options.
You may try to connect your SSD with the eSATA port, but I doubt, that this will work because of the different eSATA/SATA cable slots.
As last option I recommend to ask a friend with a desktop pc, if he/she may allow you to flash the firmware into the SSD. Connect it to the first SATA port. The related SATA Controllers should be set to "IDE Mode". After having successfully flashed the Firmware, you can remove your SSD from the desktop pc and reinsert it into your notebook. Your friend can reinsert the SATA cables of his/her hdd, restore the previous BIOS settings and continue the work without any problems. His/her data will not be affected at all.
Little side note: Don't expect, that you have to repeat this procedure very often. Frmware updates are not as often released as new driver versions.
Fernando
Community Manager
Thanks Fernando.
I was able to update the firmware by installing the SSD in another notebook which recongnized it. I hope HP will find a solution for the next time!!
Happy Holidays
Community Manager
...Also confirm you follow firmware directions to set BIOS to a mode like legacy, compatibility, IDE, etc. if you have it.
Occasionally you might need to connect the drive to another computer, too (but my own need to do that with prior firmwares was fixed with the current one.)
Community Manager
Thanks for the reply.
I installed the latest HP ENVY bios, but as far as today the bios does not have any option to set legacy or compatibility. Are you saying that the first time you had to update your SSD by connecting it to another pc...but then every other firmware update tool worked just fine by just running the bootable cd in your pc?
