Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
Intel X25-M 80GB Raid 0, do these numbers seem right?
I have an Asus P6X58D Premium mobo, and 2 80GB X25-M G2 SSD's Do these numbers look right for them? the write seems very slow, thanks in advance
Community Manager
updated chipset drivers to latest 10.0.0.1046 and got these
Community Manager
Have you enabled write-back cache in RST? And you can try in device manager > under disk drivers > your array > properties > policy > check Turn off windows write-back buffer flushing on the device.
But the X25-M only has a 70MB/s per SSD sequential write speed so your looking at a max of 140MB/s for write speeds which is more or less what your getting.
