cancel
Showing results for
Search instead for
Did you mean:
Intel X25-M G1 80GB SSD hangs/freezes in Windows 7
Esteemed Contributor III
About a week ago, I bought Intel X25-M SSDSA2MH080G1 80GB SATA II MLC from NewEgg.com.
I plugged in the new SSD as my main (OS) drive (all my specs are in my sig.) and started installing Windows 7. During install I split the drive into 2 partitions: 20GB for win7 & the rest. On the first attempt win7 install froze at "completing installation" stage, iirc. As it was only my 2nd attempt to install windows 7, and first attempt to install it on the desktop pc, I waited for it to "unfreeze" or continue for ~30 min. Finally I gave up and had to push the reset button. I did my first windows 7 install that very same day on my Acer AO751h netbook and it went smoothly and pretty **** fast (and is still working perfectly).
On the second attempt I was able to install windows 7 successfully. I deleted partitions during second install and recreated/formatted only 1 partition 20GB for win7. The 2nd partition I created/formatted already in windows 7. Just after installation, on my first log in to windows 7, I installed Acronis True Image Home 2009 and tried to create an image of my fresh win7 OS partition. That is something I always do, I like having last fresh windows install image for quick "fresh restore", especially in this case, as I knew there are numerous tweaks to be made, to optimize SSD drive usage. Creating the image failed, as True Image software froze and shortly after-wards windows completely froze as well. At that point I had 5 Seagate 1.5TB (ST31500341AS) drives connected to my pc. Knowing the story behind those drives and from my own experience (from the 17 Seagate 1,5TB drives I had, 2 developed freezing/hanging problems), I obviously suspected the problem was one of them. I disconnected all drives, but Intel's SSD and tried to make partition image again. I probably tried 5-6 times and all attempts failed. By now I wasn't sure, maybe True Image was not working properly on windows 7, so I gave up on making image. I used windows 7 for a couple of days, applied tweaks for SSD, like moving paging file, temp files, disabling system restore, hibernation, indexing, superfetch, defrag, firefox memory cache, etc. Windows 7 was flying, I was ecstatic seeing the performance of windows. Though time from time, windows would just freeze up and nothing helped, but the reset button.
I started googling for solutions. All I could find, that maybe Intel SSDs have trouble with nForce chipsets (ironically, neweeg product review that was posted just yesterday put me on this track).
The questions I would like to ask:
What software should I use to diagnose this SSD? I could not find any tools on Intels site, and googling for SSD diagnostic tools gave me nothing.
Is the incompatibility of nForce chipset an Intel SSD the main and only reason for these hangs and freezes? Does the new G2 drives have this problem as well? If it is, I need to think about returning this drive.
Any other ideas/solutions?
I'd be very disappointed to return it, after experiencing the performance boost it delivered, when it was working
Thanks in advance.
85 REPLIES 85
That was the first thing I did when it didn't work. Sorry, the driver didn't help.
CHend7
New Contributor
I had the same problem when I had a pair of X25-E's attached via Raid 0 to my ASUS P5E3 Premium motherboard running Vista Ultimate. After over a week of investigation I came the the conclusion that the Intel ICH9/ICH10R chipset could not handle the load so I went out and purchased a RocketRaid stand-alone card and was very happy when the problem went away. A friend then referred me to the following thread. It is a very long thread BUT it basically proves that there is something wrong with the Intel Matrix Driver version 8.9. To cut a long story short, all I had to do was move back to the previous revision of the driver and the problem went away. Windows 7 ships with version 8.9. I don't know how to wind it back to 8.8 on Windows 7. The reason I suspect that you are all suffering the same fault is that the failure you are describing is consistent ie freeze on one application and then degradation until everything freezes. If you check your event logs you will find the error in there. (Check through the thread to see the full details). I am aware that most of you aren't Raid users but when I tried an X25-E without Raid I found the same problem. Let's face it, with a high performing SSD you are certainly stressing any controller.
If you have the time, read through the thread and you will notice the common theme.
Whichever way you look at it, Intel has a problem!
/thread/5036?start=120&tstart=0 http://communities.intel.com/thread/5036?start=120&tstart=0
Hi folks,
I think I'm having the same problem and would like to ask if this issue confined to Windows 7, as I am running Vista x64 Ultimate.
I'm using an Intel X25-M SSDSA2MH080G1C 80GB SATA II MLC connected to a Gigabyte GA-EP45-UD3P (Intel® P45 + ICH10R Chipset). The drive is connected to the onboard Gigabyte RAID mode (but running as a native SATA drive). I am NOT running it in AHCI mode. Drive has been updated to latest firmware revision
Previously I had been using a pair of WD RaptorX 150GB drives in RAID on the system and it worked flawlessly.
The system occasionally hangs and then resets itself, usually without any warning (occasionally I'll get a BSOD complaining about NTFS). I have even had it reset during HDD detection in the BIOS once. Occasionally applications will become unresponse for 10-15 seconds and the hard disk light will go solid. There does not seem to be any specific action that is causing the system to hang.
I've run memtest x86 and it found no problems.
I would consider myself a power user and usually have a couple of virtual machines running XP, so the SSD has been used moderately over the 2 months it has been installed.
Also, do we have any info if the G2 revision fixes this kind of issue?
Thanks in advance.
I do not want to patronize anybody giving some help is the purpose, I'm seeing a lot of complaints about SSD's in raid configurations and even a one SSD installation; malfunction blamed on the drives regardless Intel or other brands.
Most users are not familiar installing SSD's, installation is a bit different bios settings are different, raid connections are different than with regular HDD's, for example raid using sata port 0 and 2 or 1 and 3 or 4 etc will work with HDD's not with SSD's connect to 0 and 1 works great update your Mobo with the latest bios before you start, check your SSD (s) for the latest firmware etc. In 99% of the cases there is no problem with the drives. Problems are related to incorrect configuration or installation. A fact though: Intel's manuals and help files are not the best. SSD technology is still very new. I believe Intel has done a great job; their SSD's are amongst the best.
Installed about 400 Intel SSD's in our data center, different kinds of raid plus additional ones in workstations & desktops, still have to encounter the first malfunction.
So friends before you start installing your SSD (s) get your ducks in a row and everything will work fine.
Hope this helps,
Roland
My system in raid 0
I'm one of the one's having problems. If you also look at this thread: http://communities.intel.com/thread/5036?start=0&tstart=0 you'll see this is wide-spread. I don't post until I tried everything out myself. I've tried every sata jack, even though it SHOULDN'T make a difference. I've tried AHCI and legacy mode; legacy mode works, but is slow. I checked firmware and drivers. I have no raid configuration to worry about and it still hiccups, freezing the whole system in the same way as others. That's the part that is making us band together, it's a similar issue with consistent symptom patterns among all of us. It's not my fault and I have my ducks in a row. I worked as an engineer at Micron on the memory they made these new SSDs with. With all due respect, which isn't much, I doubt that all the people on here are all simultaneously at fault and the answer is that we all deserve a stupid award. Some people without your luck have put quite a bit of time into this and to have someone who doesn't have this problem come in and say it'll work if you just do it right and then continue on to post how great your numbers are is a bit pretentious or, as you already claimed, patronizing. And to say that SSDs are different and only work in certain sata channels is just plain wrong. The bios settings affect sata drives the same because you're only dealing with configuration settings with the sata interface which is one layer abstracted from the actual media itself. The only thing that matters is that you plug the drives to be raided into ports that are all connected to the same raid controller. I would care less about your cavalier attitude if I hadn't spent so much time on this and seen so many others with the same unique failure pattern. I'm happy yours works and you have such high numbers though.
On a side note, I was able to recover once from the dreaded pauses and inevitable lockup by quickly unplugging and re-plugging in the sata cable connector while it was trying to die. And NO, it wasn't a bad connector or not pushed in all the way. The system started to hang, the activity light came on solid while not doing anything and then lost response from the system except for the mouse and apps that were already open and not needing to access the hard drive. I quickly unplugged, plugged back in and it came right back. I haven't tried since. I had the idea after reading about timeout issues with the drives causing similar symptoms.
At least Intel is appearing to hear us as they've set up a slew of test machines to track this down, specifically those with ICH9/ICH10 sata controllers with the 8.9 driver. Again, see linked thread above for status.
Don't know if I've mentioned this before, but mine's a G2 drive.
