Learn how to delete system and back up partitions on hard disks. You may sometimes exceed the allowed amount of system partitions on a hard disk. I assume the 'clean' way should work.
Maybe. It sounded like you are having problems with the virtual boot. If you mean to say that your problem is the actual host system. Then I can assume I can blame the update services or something like that. Your host system can have some hidden issues like indexing and virtual memory allocation. I wish I could have a permanent solution encyclopedia. But, I am doing this from memory. This is all covered on the MSDN website it plagued details. If you're blaming the RAID configuration then provide details of how new this configuration is. It may very well be that your enclosure has some severe settings that are affecting your system.
From just the details of the problem. It sounds like your laptop booted from that 4gb drive and registered itself in the system of the operating system partition. I am pretty sure in the registry. It just created a user profile. Something similar to any computer TPM device.
Hello, @Kissel-b.
Thank you for posting on the Intel Community forums.
I reviewed your thread and, unfortunately, there are no recommendations we can provide as the use of enclosures/adapters with our drives is not supported nor validated by us, although it is possible that this is driver-related as you mentioned.
What is the exact model of the SSD? Based on your description of the drive we would usually recommend installing the Datacenter NVMe* Microsoft Windows* Driver, but this does not apply to your scenario as it is intended to be used with the drive directly connected to the system.
- Datacenter NVMe* Microsoft Windows* Drivers for Intel® SSDs: https://downloadcenter.intel.com/download/29984?v=t
Your thread will remain open in case a community user would like to participate or in case you would like to share your findings with the community, but it will not be monitored by us for support. Please open a new thread or contact us via any of the other support methods (https://www.intel.com/content/www/us/en/support/contact-support.html) if you have other questions or require any type of assistance from Intel in the future.
Bruce C.
From what I am reading on the internet you can just replace the current iastorac.sys file. I am not familiar of what this file compares to. But, should be easy to back up. My guess it's a page file. Delete and restart the computer.
