Community
cancel
Showing results for
Search instead for
Did you mean:
rvict
Intel dc p4500 speed caped?
On tests the read speed of dc p4500 never gets higher than 1500MB/s. Same results on different systems and motherboards(pci 3.0).
There is some way to circumvent that?
Community Manager
Hi victer,
We understand your concern regarding the performance of the Intel® SSD DC P4500 Series.
In order to better address your situation, could you please provide the following information:
-What is the operating system you are using?
-Are you using the SSD as a storage device or are you using it as a boot drive?
-What is the tool you are using in order to perform the benchmark?
-Please download and install the https://downloadcenter.intel.com/download/27130/Intel-Solid-State-Drive-Toolbox Intel® Solid State Drive Toolbox. Once is installed, hit the "Export" option and attach the file.
We look forward to hearing back from you.
Junior M.
rvict
I'm using windows 2012
The p4500 is a storage device(not on production yet)
I used Crystaldiskmark to benchmark and the export is attached
Community Manager
Hi victer,
Thanks for the information provided.
Based on the logs, it seems that the SSD is connected to a PCIe port 3.0 by 2 lanes. We suggest you to install the SSD in a PCIe port 3.0 by 4 lanes.
Please let us know if that works.
Junior M.
rvict
Hello, i did try your suggestion, but no good, same speeds.
Even when i try on a 16x gen 3 slot, the speed stays the same.
Community Manager
Hi victer,
Please check your private messages.
Junior M.
Community Manager
Hi victer,
We would like to know if you read our previous post and if you have any other questions. We'll be waiting for your response.
Junior M.
