If I take a look inside the NVMe controller it says "This device cannot start (Code 10): hardware error in an I / O adapter".
Actually i run the OS on optane.
- There are many factors that can cause this situation. For example: correct set SATA mode in BIOS (should be "Intel RST...."), hardware remapping on PCIe slot should be disabled. The OS should be installed on the slow part of the drive rather than on Optane part. The Intel RST Windows driver should be version 17.x or later.
- Please read the Installation Guide for Optane Memory and correct your installation accordingly.
Leon
Leon
Topic Options
