Community
cancel
Showing results for
Search instead for
Did you mean:
RealOgul
Intel m2 nvme 660p
In the Intel SSD Toolbox it is saying, that my ssd is full working but if I do the test on my windows explorer it says that my ssd has a mistake. I tried repairing it with windows but it is saying it is still broken. But my Ssd toolbox is saying it is fine what could I do I need help.
n_scott_pearson
Super User Retired Employee
There is a significant difference between the SSD Toolbox, which is displaying the physical status (health) of the drive, and Windows File Explorer, which are displaying the status of the file system that is stored on a partition of the drive. The former is telling us that there doesn't seem to be any physical problems with the drive (which is good), while the latter is telling us that there may be some corruption in the file system (which is not so good).
What you need to do is run the CHKDSK tool in fix (repair) mode with a command-line like "CHKDSK C: /F" (change the "C:" if it is a different drive letter having the problem).
Hope this helps,
RealOgul
Hello n_scott_pearson,
Thank you for your answer but i tried this already and I am still getting  the notification that it has a mistake I nearly tried every method in the cmd and in the windows explorer I don´t know what I could do else.
n_scott_pearson
Send us a picture of the error message you are seeing. Capture the output from the run of CHKDSK into a file and include it in the response.
RealOgul
I also restarted it after it but it is sazing that it is onlz looking for mistakes
n_scott_pearson
Try using the tool with a command line like this: "chkdsk c: /f /offlinescanandfix".
RealOgul
n_scott_pearson
Where should I tap this command in the cmd because i tried it there and I am still geting this mistake notification. Or shoul I try this somewhere else.
n_scott_pearson
It should say it will run during the next reboot cycle and then do so.
RealOgul
n_scott_pearson
It didn´t work again I am still getting this misttake message
LeonWaksman
Hi @RealOgul
Try to run from Administrative Command prompt : chkdsk c: /f /r  This command should locate bad sectors.
Leon
RealOgul
Hi LeonWaksman,
I tried it but I am still getting this mistake notification if I am testing it.
LeonWaksman
Hi @RealOgul ,
1. What is the status reported by chkdsk after finishing run this command? Are any errors reported?
2. The Drive E: and F: are partitions of the same drive C:  or there are separate drives?
3. Did you run chkdsk on E: and F:? If not, please do this.
Leon
Tags (1)
