cancel
Showing results for
Search instead for
Did you mean:
Intel(r) SSD Toolbox is ready to go!
Alan_F_Intel
New Contributor III
New Contributor III
Hey everyone,
Good news (just in time for the holidays)! We have released the new version of the http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18455 Intel® SSD Toolbox (version 1.2) which fixes the issue with the Intel® SSD Optimizer.
rgds,
Alan
Intel NSG Marketing Division
74 REPLIES 74
Esteemed Contributor III
Took 45 minutes for my 80 gig G2. Worth the time though. Way better performance.
So, just to confirm: if I am running 2 SSDs in a RAID0 configuration, I won't be able to utilize this toolbox (including optimizer) ?
In my case it just says "Failed":
I reinstalled Toolbox v.1.1 and it shows me that everything is fine:
After that I installed new drivers (Intel® Rapid Storage Technology v.9.5.0.1037) for my Intel(R) ICH9M-E/M SATA AHCI Controller and nothing has changed, Toolbox 1.2 shows the same error and 1.1 works fine.
My system:
Win 7 x64
HP EliteBook 6930p
T9400, PM45 chipset, ICH9M-E/M SATA AHCI Controller
SSDSA2M080G2GC with last (HD) firmware with such SMART attrib:
What's wrong?
WWong10
New Contributor II
I have the same problem as Isidur.
I get the error screen when trying to run an optimization.
Here are my system details:
Windows 7 - 64bit
Zotac 9300 Mobo (Nvidia 730i chipset)
Intel 80GB G2 Postville (2CV102HD Firmware)
Standard AHCI 1.0 ATA Controller Driver (3.0Gb/s SATA)
Drive Policy - Better Performance, Write Caching on, Write Cache buffer flushing off
The new toolbox says this when making a scheduled TRIM task:
The Intel SSD Optimizer may take many minutes to complete. While in progress, only 1 GB of space will be left free on your drive. Please avoid/minimize system use at the times you have scheduled the Optimizer to run. Once complete, all free space will be returned.
So, this toolbox fills the entire drive but 1GB with data and then frees it again to achieve the same as the old toolbox without corrupting restore points? If yes, this behavior increases host write load on the SSD by its capacity minus 1GB every week - I dont think I want that. I'll stick with the old toolbox. Not using windows restore points anyway...
