cancel
Showing results for
Search instead for
Did you mean:
Intel ssd 520 remains locked after resuming from sleep if ATA HDD password set
JDous
New Contributor
Recently, I upgraded my HP 8560w notebook to windows 8.1, installed a new Intel 520 SSD. Without setting ATA password everythink works fine. After I set up an ATA HardDisk Password (in order to enable FDE (full disk encryption)), the notebook can not resume from SLEEP. Pressing sleep button puts the notebook into sleep. Pressing power button resumes from sleep, shows login screen, it lets me type my windows password, then it fails to show desktop, and windows crashes with BSOD.
After restart, SSD Toolbox shows bit3 (security frozen)=1 at word 128 in drive details.
Removing ATA HDD password helps, but it is not THE solution, since i need the encryption.
Event viewer shows Error Event 41-Kernel power (critical), "system has rebooted without cleanly shutting down first".
I have already seen different forums and threads, but actually nothing helps.
There is also identical question already present in this forum, but without working solution
Disabling ATA password for Intel SSD, using it just for my secondary HDD (Hitachi magnetic non SED drive) in upgrade bay, works fine, notebook is able to resume from SLEEP, secondary drive is unlocked and available.
Windows 8.1 x64, latest updates, latest bios, latest 520 firmware (i400).
Thanks for help,
Dousin
7 REPLIES 7
Jose_H_Intel1
Valued Contributor II
We have been trying to replicate your issue without success. I noticed that resuming from sleep does not trigger the Hard Drive password screen but hibernation does, I had to enable hibernation in Power Options (Choose what the power buttons do). Both options worked just fine.
I wonder if you could provide more information such as a screenshot from disk management and any details about the error from Event Viewer or the (BSoD) minidump file. Furthermore, does the issue happen when the mechanical drive is not connected to the system?
The issue happens even if secondary HDD disconnected.
I use MBR partition table.
There is 350 MB additional partition on the disk , which is currently not used.
Disk Manager Screenshot
Log from Event viewer (critical issue)
Log Name: SystemSource: Microsoft-Windows-Kernel-PowerDate: 30/03/2014 23:02:46Event ID: 41
Task Category: (63)
Level: CriticalKeywords: (2)User: SYSTEMComputer: dousinnotes
Description:
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly.
Event Xml:
http://schemas.microsoft.com/win/2004/08/events/event http://schemas.microsoft.com/win/2004/08/events/event">
41316300x80000000000000025997Systemdousinnotes
00x00x00x00x0400
Jose_H_Intel1
Do the partitions and unallocated spaces have some specific purpose, like for another operating system?
Is it possible to attach some minidump files from C:\Windows\Minidump? You can used the advanced editor for this.
