Solid State Drives
Support for Issues Related to Intel® Solid State Drives
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
4365 Discussions
Intel ssd 530 nforce mcp79 Asus k70IO
ANowa4
Hi.
Only getting SATA Gen 1 Speed with INTEL 530 SSD on my laptop. CHip is nforce nvidia.
My Laptop have SATA II. Normal hard disk works in SATA II speed.
Could intel correct this bug in the next release firmware to the this drive?
Sorry for my bad English. I from Polnad.
Kevin_M_Intel
Hi Seto,
I am sorry you are having problems with the SSD but let me help you.
Based on the information you have provided, I recommend you doing the following:
1. Update the BIOS on your computer to latest using the one provided by the Computer Manufacture. Here you can get it:
http://support.asus.com/download.aspx?SLanguage=en&p=3&s=197&m=K70IO&os=29&hashedid=1F6tUuPwvmoqxSbZ http://support.asus.com/download.aspx?SLanguage=en&p=3&s=197&m=K70IO&os=29&hashedid=1F6tUuPwvmoqxSbZ
2. Update the SSD firmware. Here you can download the software:
https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=18363&lang=eng&ProdId=3767 https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=18363&lang=eng&ProdId=3767
Kevin M
