Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
IntelBootLoader - 8.4 GB
Hi , I have some issues with my ssd Intel Postville.
At the begining he was correctly detected as SSDSA2M080G2 and 80Go of size. It was also working with as OS on it.
But since tonight he is detected as : IntelBootLoader - 8.4 GB in the bios. and we can't boot on it.
Someone havethe same issue? how can I solve the issue?
Cheers.
Jonathan
Community Manager
RMA is the only solution, unfortunately.
Community Manager
Why? Is it a konw issue?
Thanks for having replied fast.
Community Manager
Have you tried a secure erase, its worth a try. <!--[if gte mso 9]> Normal 0 false false false EN-US X-NONE X-NONE MicrosoftInternetExplorer4 <![endif]--><!--[if gte mso 9]> <w:Lsd...
Community Manager
I don't understand the link betwin the software that erase the data and my issue. Moreover this soft should recognize only 8.4G of my ssd.
Community Manager
My point is that if it is only recognized aas an 8.4 bootloaader mayybe if you wipe the hole ssd, it might recognize it afterwards as normal. I saw this a couple of times when the ssds were only being recognized as 8mb. so it mioght work, if not just rma it then
Community Manager
Cpt.Dogfruit I have try you're sollution. It doesn't work.
Anyone have another idea to solve this issue without using the RMA solution?
Community Manager
I have exactly the same issue with my SSD.
My PC refuses to boot on it and now my SSD is detected as "IntelBootLoader".
I cant succed in making a full erase on it.
So anyone have another solution ? It will be very helpfull...
Thank you very much.
Thomas
