Solid State Drives
Support for Issues Related to Intel® Solid State Drives
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
4365 Discussions
Internal IO timeout on Intel NVMe drive
JLee157
Hello Team,
My customer informed that NVMe drive on Servers disappears all of sudden at OS level
Array controller can't recognize the drive either.
That happens across multiple servers.
As a workaround, they tried NVMe drive replacement, then it fixed
So it seems to be a NVMe drive issue itself.
For testing, NVMe command(identify Device) was used,but report a "internal Device Error" to any subsequent commands
I wonder If this is a known issue for Intel SSD (NVMe) drive
If known issue , what is best practice ?
The exact model: Intel SSD DC P4600 1.6TB (2.5" NVMe/PCIe SSD 1.6T)
Thanks for your answer in advance
Cheers
JY
Community Manager
Hello jaeyoung,
Thank you for contacting Intel® Technical Support.
As we understand, you need assistance with your Intel® SSD DC P4600 Series (1.6TB, 2.5in PCIe 3.1 x4, 3D1, TLC). If we infer correctly we will appreciate if you can provide us with the following information:
  • In case that you are using Windows provide us with the following:
  • A screenshot of the "Disk Management" of Windows* showing all your HDDs and partitions.
• The SMART logs extracted from the Intel® SSD DC P4600.
The Intel's Data Center Tool (DCT) can be used to read out the SMART attributes to download this tool please follow this link:
https://downloadcenter.intel.com/download/27863/Intel-SSD-Data-Center-Tool https://downloadcenter.intel.com/download/27863/Intel-SSD-Data-Center-Tool
We will be looking forward to your reply.
Josh B.
Under Contract to Intel Corporation
Community Manager
Hello jaeyoung,
Thank you for having contacted Intel Technical Support.
This email is just a friendly reminder that your case remains open.
Should you need our technical assistance please do not hesitate to contact us back.
Josh B.
