Community
cancel
Showing results for
Search instead for
Did you mean:
EF
Is XenServer 7.0 support Intel DC P3608 ? and how to configure to raid 1 ?
I would like to install DC P3608 on the XenServer , is it support ? and how to configure to raid 1 ?
Tags (1)
Community Manager
Hello eeFF,
We understand that you would like to verify if the SSD DC P3608 is compatible with the XenServer 7.0. First, let us tell you that this SSD is an NVMe* drive, it has not been tested in that particular OS, so we cannot confirm if it should be supported.
Based on the https://docs.citrix.com/content/dam/docs/en-us/xenserver/xenserver-7-0/downloads/xenserver-7-0-techn... technical specs of the XenServer 7.0, page 8, we noticed that there is no mention of the NVMe* support on the OS. We highly suggest to you to contacthttps://www.citrix.com/contact/ Citrix* for better support in this case.
Also, for this SSD, Intel only supports RAID 0, using other RAID levels may result in loss of data.
Nestor C
Community Manager
Hello eeFF,
We would like to know if you were able to read our previous post and if you have any more questions. We'll be waiting for your response.
Nestor C
