cancel
Showing results for
Search instead for
Did you mean:
Is it alright if my x-25m v2 was accidently defragged?
Esteemed Contributor III
Hi All,
I installed O & O defrag to use primarily on my Disk Drives. Monitoring was disabled but it started doing an optimize\quick defrag and only took like 5 seconds.
Is that going to damage my drive.
Thank you,
Fo
3 REPLIES 3
Disk defragmenter is not beneificial to SSD.
I know that...
I installed the program to defragment my other disk drives that are not Flash/SSD.
A few defrags is nothing to worry about.
Run the Intel Solid-State Drive Toolbox (Ver 1.3) and click Check SMART Attributes.
Look at Media Wearout Indicator. It will probably be normalized to the high 90's which means like new.
