Community
cancel
Showing results for
Search instead for
Did you mean:
AAnos
Is it possible SSD with Windows XP ?
Jump to solution
Can Intel Toolbox do garbege (trim) for XP ?
Kevin_M_Intel
Hi AlexAn,
Trim can be enabled from Toolbox when using XP. This will also depend on the hardware you have. Make sure the SSD is connected to an Intel® SATA Controller and Intel® Chipset.
Kevin M
Kevin_M_Intel
Hi AlexAn,
Kevin M
