Community
cancel
Showing results for
Search instead for
Did you mean:
SDzha
Is my SSD 510 drive dead?
I purchased two 120GB SSDs Intel 510 Series.
SSDs were installed in different computers.
The 1st drive was installed on an ASUS P8Z68-M PRO motherboard, as my operating system drive (Win 7 x64), using on port 0 respectively of the Intel controller. The SSD was in AHCI mode. I ran Intel's SSD Toolbox followed by running the SSD Optimizer for drive. It was all ok. System worked 100% fine for about a month.
However, once the drive fails to boot. The BIOS recognized the SSD, but it seems that the drive doesn`t have partition. I tried to make partition with the Parted Magic and the Acronics software's, but it doesn't recognize the SSD.
Then I tried to install SSD in other PC (ASUS P8H67-M PRO, Win 7x64, with my 2nd SSD Intel 510), same things. BIOS does see this drive, Windows and Intel's SSD Toolbox doesn`t see the drive. I mount my 2nd drive (Intel 510) in the 1st PC (ASUS P8Z68-M PRO) at same port, it works well.
It looks like the problem is in the 1st drive.
Does this indicate a bad drive?
Tags (1)
