Community
cancel
Showing results for
Search instead for
Did you mean:
OZott
Is the SSD 750 series compatible with Intel Mainboard DZ77GA-70K?
Jump to solution
I know that Intel has said that this SSD only supports Z97 and X99 mainboards fully, but since it really depends on the BIOS I wanted to be sure.
It will most likely work as a data drive, when the operating system handles everything, but I would like to use one as a boot drive.
Is that possible or will it maybe get a BIOS update so that it becomes possible?
ASouz7
Hello oliewa92,
We would like to inform that it will not work as boot drive in the Intel® Desktop Board DZ77GA-70K. Please bear in mind that this board as well as Intel® Desktop Board DZ87KLT-75K are EOL (End Of Life) and there will be no further BIOS updates.
ASouz7
Hello oliewa92,
We will check on this for you. In the meantime, please take a look at the information below that might help you as well.
http://www.intel.com/support/ssdc/hpssd/sb/CS-035481.htm Intel® High Performance Solid-State Drives — Booting an NVMe* PCI Express* Solid State Drive
http://www.intel.com/support/ssdc/hpssd/ssd-750/sb/CS-035483.htm?wapkw=intel+ssd+750+series Intel® SSD 750 Series — Frequently Asked Questions (FAQ)
ASouz7
Hello oliewa92,
