cancel
Showing results for
Search instead for
Did you mean:
Is there a way to run the SSD toolbox from a Windows command line?
RSick
New Contributor
Is there a way to invoke the SSD toolbox from a Windows command line?
I've got a bunch of SSDs and would like to run things like a full diagnostic scan, or retrieve the SMART details for a drive once in a while.
Is there a way to invoke the SSD toolbox and pass it parameters to run the full, (or quick), diagnostic, or perhaps retrieve the drive and/or SMART details and then redirect this information to a file?
Something like
"c:\Intel Toolbox SSD.exe" /S /F > c:\temp\SSD_run.txt
2 REPLIES 2
Jose_H_Intel1
Valued Contributor II
Thank you for sharing your inquiry with us.
The Intel® SSD Toolbox was only designed to be used from its graphic user interface.
I am sorry for any inconvenience this may cause.
Jose_H_Intel1
This free tool might be of help. We have not really tested it but it offers command line support.
http://hddscan.com/ http://hddscan.com/
