Intel® Optane™ Memory
1345 Discussions
Is there any SSD M.2 compatible to i5 7th gen 7300HQ
GRigo
My notebook has a i5 7th generation 7300HQ and there is an open port which I can install a SSD type M.2? I have checked intel's SSD Optane but it doesnt have for my core.
I really want to upgrad emy notebook with an SSD.
The website below is where I read about it whether it is compatible.
https://www.intel.com.br/content/www/br/pt/architecture-and-technology/optane-memory.html Memória Intel® Optane™ – Memória revolucionária
Hi gallardo.ggr,
We understand your concern regarding an M.2 SSD that could be compatible with your system.
We would like to let you know that the Intel® Optane™ Memory is designed for accelerating SATA drives and we do not support the usage of this module as an SSD.
In this case, we recommend you to contact your https://www.intel.com/content/www/us/en/support/topics/oems.html system manufacturer in order to verify if your system supports NVMe or SATA drives.
In case your system supports the NVMe drives, we recommend you the http://ark.intel.com/search?q=Intel%C2%AE+SSD+600p+Series Intel® SSD 600p Series.
If your system supports SATA drives, we can recommend you the http://ark.intel.com/products/125021/Intel-SSD-545s-Series-256GB-M_2-80mm-SATA-6Gbs-3D2-TLC Intel® SSD 545s Series.
If you need anything else, please let us know.
Junior M.
Hi gallardo.ggr,
We haven't heard back from you in a while. We would like to know if you have further questions or concerns we can assist you with.
Junior M.
