Community
cancel
Showing results for
Search instead for
Did you mean:
ssilv7
Is this a counterfeit or real Intel SSD? I can't find any info on it. Please advise!
Jump to solution
I found http://www.alibaba.com/product-detail/Intel-SSD-535-Series-120GB-SSDSC2BW120H601_60199447536.html?sp... HERE same model with same package and same ID's. I bought this SSD in a large electronics store and IT products in my country and I suspect they sold me a fake intel product.
As you can see in pictures around back sticker the aluminium is dirty and not finished or polished, this is normal? Should I worry or everything seems alright?
jbenavides
Hello Silviu_25,
The base plate of Intel® SSD's normally has the unfinished look and patterns due to the type of metal used. This side of the drive is not visible once the drive is installed so it is non-polished.
We checked the pictures of the drive and it seems to be an original Intel® SSD 535 Series. The drive's markings and sticker look OK. Here are some useful links:
http://ark.intel.com/products/86738/Intel-SSD-535-Series-120GB-2_5in-SATA-6Gbs-16nm-MLC# @ordering Intel® SSD 535 Series (120GB, 2.5in SATA 6Gb/s, 16nm, MLC) Specifications
http://www.intel.com/p/en_US/support/warranty Warranty Center
jbenavides
Hello Silviu_25,
ssilv7
Oh thank you!
Now I'm calmer. I thought I was tricked.
I just installed and is super. It is a wonderful device with amazing speeds.
TYan3
I hate how awful is the base plate of 530. I miss the quality (case and internal) of X25-M 50nm.
Btw both the SN and the WWN are different.
jbenavides
Thanks for your comments, we appreciate your feedback regarding the look of the back faceplate and will forward it for future consideration.
Regarding the SN and WNN, they are unique identifiers required for different purposes. The WWN is necessary by some storage technologies, and the ISN is the actual serial number from Intel, so they are both printed in the SSD stickers.
