cancel
Showing results for
Search instead for
Did you mean:
Is this speed to be expected?
Esteemed Contributor III
Good morning every one!
I just got a new PC and installed SSD. Sytem Info and speed as follows:
Model: Fujitsu T900 Tablet
CPU: core i7
RAM: 4 gb
HDD: Intel x25m 80G SSD
I simply removed the existing HDD and replace it with the SSD. Then I did a clean installation. I did not manually install TRIM, Toolbox, Intel driver or Intel Matrix Storage Manager.
My questions are:
1. Is the speed OK?
2. Do I need to install Toolbox, Intel driver or Intel Matrix Storage Manager?
3. TRIM is enabled (I checked with the CMD method) but does it only work when toolbox is installed?
I am a layman and would appreciate your advice. Thank you.
1 ACCEPTED SOLUTION
These are my results:
I'd suggest you follow these instructions and also the link to the SSD toolbox within the pdf: http://www.intel.com/support/ssdc/hpssd/sb/CS-031549.htm http://www.intel.com/support/ssdc/hpssd/sb/CS-031549.htm
10 REPLIES 10
Hi Michael,
Thanks for your advice.
Yes, ACHI is enabled. And my windows experience index isn only 4.6...
Although TRIM is auto-enabled in Win 7, I wonder if installing and runing Toolbox helps?
I'm not entirely sure what your fundamental problem is although with a WIE of 4.6 something is wrong. It could be motherboard related or perhaps there's a problem with the SSD? Perhaps if you try another HDD in your computer and see what the benchmarks are for that? If those are abnormally low then that may rule of the hard drives.
Hi Michael,
Thanks for your info. I will try to find out how to improve my windows experience index. By the way, I have installed the toolbox and run the optimizer once. The result shows some improvement. The read result seems pretty close to yours but the write still lags a lot.
There are plenty of reviews out there outlining what kind of speed you are likely to get with the 80GB version, (make sure you check whether they are reviewing the 50nm or 34nm though.) The main real world difference I've noticed is faster boot times and loading games and programs are much quicker. The slowest part of my PC (my HDD) has now become the fastest
Michael has a 160 GB, which supports faster writing than your 80 GB.
